7 Replies Latest reply on Oct 16, 2017 6:27 AM by BKBK
    ColdFusion Encryption
    Tayyab Hussain
      I have the following PHP Code that uses an AES/ECB/PKCS5Padding
      PHP Code:
      $hashRequest = '';
      $hashKey = 'HM53BC0C176Z58PV';
      $mapString='
      amount=30.0&autoRedirect=0&emailAddr=fakhar.munir88@gmail.com&expiryDate=20190721 112300&mobileNum=03345400644&orderRefNum=1008&paymentMethod=MA_PAYMENT_METHOD&postBackURL =http://shopweb.windsorparking.com/php/getToken.php&storeId=3528'
      // Encrypting mapString
      function pkcs5_pad($text, $blocksize) {
            $pad = $blocksize - (strlen($text) % $blocksize);
            return $text . str_repeat(chr($pad), $pad);
      $alg = MCRYPT_RIJNDAEL_128; // AES
      $mode = MCRYPT_MODE_ECB; // ECB
      $iv_size = mcrypt_get_iv_size($alg, $mode);
      $block_size = mcrypt_get_block_size($alg, $mode);
      $iv = mcrypt_create_iv($iv_size, MCRYPT_DEV_URANDOM);
      $mapString = pkcs5_pad($mapString, $block_size);
      $crypttext = mcrypt_encrypt($alg, $hashKey, $mapString, $mode, $iv);
      $hashRequest = base64_encode($crypttext);
      // end encryption;
      My ColdFusion Code So Far
      <cfset mapString = "amount=30.0&autoRedirect=0&emailAddr=fakhar.munir88@gmail.com&expiryDate=20190721 112300&mobileNum=03345400644&orderRefNum=1008&paymentMethod=MA_PAYMENT_METHOD&postBackURL =http://shopweb.windsorparking.com/php/getToken.php&storeId=352" />
      <cfset theKey = toBase64("HM53BC0C176Z58PV") />
      <cfset theAlgorithm = "AES/CBC/PKCS5Padding" />
      <cfset theEncoding = "base64" />
      <cfset theIV = "HM53BC0C176Z58PV" />
      <cfset encryptedString = encrypt(thePlainData, theKey, theAlgorithm, theEncoding, theIV) />
      <cfoutput>#encryptedString#</cfoutput>
      The Results are different
      Can Any one Help
        • 1. Re: ColdFusion Encryption
          BKBK Adobe Community Professional & MVP
          Before we go any further, the storeID in the PHP query-string is 3528, whereas it is 352 in the ColdFusion query-string.
          • 2. Re: ColdFusion Encryption
            Tayyab Hussain Level 1
            Sorry my bad... stories
            is  3528
            • 3. Re: ColdFusion Encryption
              Hello BKBK,
              I tried with the correction made to storeid
              The results in PHP
              +gsH3CaifLXzoJ4TiCyqf7TPK+HnBaUEv3j5Fz41P1omhRoMOzCGcZHkYB7QfBqqlHOCBbcw8pn9lWd2JshYiQ8A2a dAzdORxq2ug60YQKY1g9yhAcaoHaPouAkEJ5D/3ZZORvxfBZvwWcDzz7BmTwawCiKet5VBhLruTsiHPY/x6DETR2gI AKp34cPwJmHSTFH2+c41PqfrySW8MqX9MxcG1x/A2ADMA7wE2nMirNlEDv+IVPF//Cjknv8K2XSJR6rdy46eiwbWnH mDpBMk4AfcKDxk7fTu2JZp7SVvkj7xIWpUS+7H9ZHTFP5VFPVl
              The Results in CF
              KjCDw7J4UP1NGTeBZpfKIasd3Wkn9xyIZDs3AC5BPMwLSsJwoB51TOxWzusupJGpjA3QUs3Np2ZJkAHqwLvXrik1PV NXZ09KEK14RGLtx0zrXg7Ze+4IyVI1thvnFVtRbLl69NZPk9zQ+Nt/C3TVV1H22ty6jcEOdue7ouPsNfNnZqu3mAau kVvMqh4+FRXbhkXLSa5ze5VdNDkBq78TQ05JNDWMCiDrF55OeJR0/QgRlB7SFL4kNoMkhxEfkc6nuhP2jhirfubuDi 1Sto6LUBtyJB5A7orqzd27CzCzKFwnrlrn3bvLSJbKFj2FL1Qc
              • 5. Re: ColdFusion Encryption
                Dear BKBK,
                What I think is that I'am not setting <cfset theIV = "HM53BC0C176Z58PV" /> correctly, If this sets then I think it might work
                Regards
                Tayyab Hussain
                • 6. Re: ColdFusion Encryption
                  Hello
                  I think I have resolved the Issue
                  <cfset input = "amount=30.0&autoRedirect=0&emailAddr=me@.com&expiryDate=20190721 112300&mobileNum=03345400644&orderRefNum=1008&paymentMethod=MA_PAYMENT_METHOD&postBackURL =shopping cart id">
                      Generate a secret key. We are going to be using a more complex
                      form of encryption; however, we can still tell the key-generator
                      that we are simply using AES (Advanced Encryption Standard).
                  <cfset encryptionKey = toBase64("HM53BC0C176Z58PV") />
                      Now, let's encrypt our secret message with AES, This AES approach
                  breaks the data up into blocks,encrypts them individually,
                  and passes the result into the next block of encryption (.... I think).
                  <cfset hashRequest = encrypt(
                      input,
                      encryptionKey,
                      "AES",
                      "base64"
                      Now, let's decode our secret using AES  and our secret key.
                  <cfset decoded = decrypt(
                      hashRequest,
                      encryptionKey,
                      "AES",
                      "base64"
                  <cfoutput>
                      Original: #input#<br />
                      <br />
                      Secret: #hashRequest#<br />
                      <br />
                      Decoded: #decoded#<br />
                  </cfoutput>
                  (Email address and shopping cart id removed by moderator)
                  • 7. Re: ColdFusion Encryption
                    Hi Tayyab Hussain,
                    Thanks for sharing that with us.
