7 Replies Latest reply on Oct 12, 2017 9:23 AM by cathy wp22010330
    Field calculations
    cathy wp22010330
      I have a form that asks questions with different possible answers to click on. Now when the answer is checked i need to have that field to equal a certain number. Then these totals would be added up for a complete total.
      For example: 1 question is:
      What is your age?
      ____ (1) 56 and over
      ____ (2) 46-55
      ____ (3) 36-45
      ____ (4) 20-35
      So if you chose 56 and over then that would equal 1 but if you chose 46-55 then it would equal 2. This field needs to be a text field i believe or a button but then the totals can calculate to a Sub Total from all questions.
      Help
        • 1. Re: Field calculations
          You should use check-boxes or radio-buttons for this. That way you could set their export values to the desired numbers and use them directly in a calculation, and you would also prevent someone from selecting two fields at the same time.
          • 2. Re: Field calculations
            cathy wp22010330 Level 1
            Thank you for responding.
            Ok i know how to do that but how do i get those check boxes or radio buttons to equal a number. For example if i put a check box/radio button for age 56 and over how does the form know that when that box is chosen to calculate (1). See what i'm saying.
            • 3. Re: Field calculations
              • 4. Re: Field calculations
                Go to the field's Properties, Options tab, and set the value as the Export value, like this:
                It has a slightly different name for a radio-button field, something like Radio Button Choice, but it's pretty much the same thing.
                • 5. Re: Field calculations
                  hmm..ok i will give it a try. I'll let ya know thank you.
                  • 6. Re: Field calculations
                    oh my goodness...thank you so much. It worked!!! Your the best:)
                    • 7. Re: Field calculations
                      Ok hoping you can help 1 more time. Now i have a field that i need total of another calculated field x 2.
                                                 Sub-Total         Factor               Total
                      Time Horizon      ____30_____        x 1        _______30_____              (example)
                      Financial Goals  ____30_____        x 2        ______  60_____               (example)
                      Risk Tolerance   _________        x 3             ____________
                      So i have totals that were calculated for the sub-totals and now need to get the Total to calculate.
                      Hope you can help so i can finish this form:)
