2 Replies Latest reply on Apr 23, 2018 5:13 AM by MonoxideWorks
    Audition Automation - effects parameters reset
    Steve Thomason Level 1
      I export a multitrack session from Premiere to Audition, add a Multiband Compressor, for example, adjust parameters with automation turned off while I experiment with the audio, get my settings just right, then I want to automate fader levels only.  I go into Latch mode, position the playhead at the beginning of my sequence, and as soon as I hit play, every single parameter of the effect is instantly reset to zero (or factory preset defaults)  Help??!  I'm used to Pro Tools, where, in the effect window, I can deselect a button to tell the effect to ignore automation data.  Can find anything like that with Audition.
      Thanks!
      Steve Thomason
      Alpharetta, GA
