2 Replies Latest reply on Oct 12, 2017 12:13 PM by editbd
    Ignore Last Digit
    editbd Level 1
      I have two fields where information is entered. When the numbers are calculated, I would like for the last digit of each entry to not be included. How do I accomplish this?
      Entry 1 is 1.23452
      Entry 2 is 1.23437
      Should be calculated in a new field as 1.2345 - 1.2343 (the two and the 7 are dropped off, respectively).
        • 1. Re: Ignore Last Digit
          One could convert the values to a string and then sub-string the string value to remove the last digit or use the Math.floor to remove the last digit when multiplied by 10,000 and dividing the result by 10,000 to restore the decimal point to the original position.
          • 2. Re: Ignore Last Digit
            editbd Level 1
            This is the code I am currently using to display the result for:
            Where Entry Sunday1 is 1.23452
            Where Exit Sunday1 is 1.23437
            This code drops the last digit and works correctly if the last digit is 5 numbers below (for example if the last digit "7" was a "6").
            var BuySell = this.getField("BuySell Sunday1").valueAsString;
            var val = this.getField("Entry Sunday1").valueAsString;
            var countDecimals = function(value) {
                if (Math.floor(value) !== value)
                    return value.toString().split(".")[1].length || 0;
                return 0;
            countDecimals(val);
            if(BuySell == "Buy")event.value = ( this.getField("Exit Sunday1").value - this.getField("Entry Sunday1").value );
            if(BuySell == "Sell")event.value = ( this.getField("Entry Sunday1").value - this.getField("Exit Sunday1").value );
            if (countDecimals(val) == "3")event.value =  event.value("Exit Sunday1").value* "100";
            if (countDecimals(val) == "4")event.value = event.value("Exit Sunday1").value * "1000";
            if (countDecimals(val) == "5")event.value = event.value * "10000";
            if(event.value >= 0)
                event.target.textColor = color.blue;
            else
                event.target.textColor = color.red;
            event.value = parseFloat(event.value).toFixed(0);
