1 Reply Latest reply on Dec 1, 2017 12:08 PM by Jon Tehero
    Criteria set-up. Display products that matches an entity parameter on mbox
    michaelt48863429
      Hi - I am trying to create a recs component that should provide product recommendations based on the entity parameter I am passing in mbox.
      In the mbox call, I am passing an entity parameter which is 'entity.status'
      In the data catalog, my products also have that attribute - entity.status.
      What I want to happen is if the value I passed to the entity.status parameter is '1' in the mbox call, I want to see in recs all of the products in my data catalog that has a entity.status = 1.
      I don't want to use the most viewed algorithm since my site is getting very low traffic.
        • 1. Re: Criteria set-up. Display products that matches an entity parameter on mbox
          Jon Tehero Adobe Employee
          Hi Michael,
          You are really close!
          If you pass in an mbox parameter (a.k.a. targetPageParameter) called "status" -- not entity.status -- this use-case will work. So set status equal to 1 in the parameter an make sure that the items in the catalog have a corresponding entity.status value equal to 1. Also make sure you are passing both of them in the same way (either as a string or a value) so that the matching isn't trying to compare different types of data. Once you are passing in the parameter status=1, you can follow the setup below. Hope that helps!
          In your Criteria Card, click "Add Filtering Rule"
          then select "Parameter Matching"
          Then you create a rule that looks like this (you may need to change the name of the mbox):
