• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
0
Menu Fonts Are So Small They are Illegible
Explorer ,
Oct 12, 2017 Oct 12, 2017
I'm working in Windows 10 on a PC (trying to switch from Mac). I have been in File Preferences and changed the UI Font Size to Large, and the UI Scaling to 200%, closed Photoshop, and nothing has changed. I can't work like this and I have a deadline.
This is what I see in the Open File  menu, which I've been living with although it sucks:
But THIS is what I see/don't see when I go to File->File Info
Views
913
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Oct 13, 2017 Oct 13, 2017
Without exact system info nobody can realyl tell you much. These issues tend to occur when system settings override or conflict with PS and it can't correctly detect the default settings used by the computer.
Mylenium
Votes
Translate
Translate
Adobe
LEGEND ,
Mylenium
Votes
Translate
Translate
Report
Report
Community Expert ,
It seems to be a high resolution display issue with Windows.
This Youtube video may be of help to you How To Make Adobe Software Display Larger On High Resolution Monitors - YouTube
HTH
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Thank you both, but I couldn't create the manifest file in the registry, because the subfolder specified in the instructions didn't exist.
HOWEVER, I did finally figure it out, glory be.
1. Create a shortcut icon on your taskbar if you don't already have one.
2. Right-click on the icon,and you will see:
   - the Photoshop icon
   -Unpin from Taskbar Window
   -Close
3. Hover the mouse over the Photoshop icon and right-click again, and the "Properties" option will be at the bottom
4. A dialog box will open, and under "Settings" is an option to "Override high DPI scaling behavior. Scaling performed by:"
5. Check it. You don't have to specify the application because you already did by using the Photoshop icon.
Votes
Translate
Translate
Report
Report
