0 Replies Latest reply on Oct 13, 2017 1:34 AM by aleksandrk13731687
    403 in link
    aleksandrk13731687
      My ios build is failed.
      I got an error:
      Error - Plugin error (you probably need to remove plugin files from your app): Fetching plugin "onesignal-cordova-plugin@^2.1.1" via npm Installing "onesignal-cordova-plugin" at "2.2.2" for ios Failed to install 'onesignal-cordova-plugin': Error: pod: Command failed with exit code 1 at ChildProcess.whenDone (/private/tmp/gimlet/2845474/project/cordova/node_modules/cordova-common/src/superspawn.j s:169:23) at emitTwo (events.js:125:13) at ChildProcess.emit (events.js:213:7) at maybeClose (internal/child_process.js:897:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:208:5) pod: Command failed with exit code 1 - You can fix this here
      But when I open the link http://docs.build.phonegap.com/en_US/support_failed-builds.md.html#plugin-error  I see 403 error
      403 Forbidden
      • Code: AccessDenied
      • Message: Access Denied
      • RequestId: A60E631451AA29DD
      • HostId: 2OO3U3YxRTEEwsV4H0b6iSJ8zCuhyznR+C1KNUs+7laORxG/scmwwEpzjXv2A4khFTHZWG/fZoI=
