3 Replies Latest reply on Oct 14, 2017 11:49 AM by steveb71530353
    How to get rid of sharp edge
    steveb71530353 Level 1
      so_sad_by_stockmichelle.pngHow to get rid of sharp edge on the right hand side of the image only?
        • 1. Re: How to get rid of sharp edge
          Trevor.Dennis Adobe Community Professional (Moderator)
          It's a stock image with transparent background, which makes life easier for you.
          Ctrl click the layer to load it as a selection, and make the selection a work path.
          Select the Pen tool, and make sure Auto Add Delete is checked in the options bar
          Hover over the path at one end of the bit you want to soften, and add a point.
          You'll see the tiny + sign in the pen icon
          Hold down the Ctrl (Cmd) key to select the direct selection tool, click away from the path, and then drag around the new point you just made, and delete it  This will break the path
          Do the same at the other end of the bit you want to soften.
          Use the direct selection tool again to select and delete the unwanted points
          Select the Blur tool and adjust the brush size and strength.
          Right click the path and chose Stroke Path
          Use the drop down to select the blur tool.
          Repeat if required
          • 2. Re: How to get rid of sharp edge
            edgrimley Level 3
            A quick way is to use the smudge tool set to a low strength around the sharp edges.
            • 3. Re: How to get rid of sharp edge
              Thank you, that was very helpful
