1 Reply Latest reply on Oct 15, 2017 4:18 AM by Silly-V
    RenderSwatchLegend
    justino48587774
      I stumbled across this awesome script, and I've used it on a few projects.   However, currently, I need to use swatches out of the Pantone+ Solid Coated book (Spot colors)
      When I convert the script from CYMK to RBG, the RBG codes come out as Nan,Nan,Na instead of the actual numbers.   I even redownloaded the script, changed ONLY line 17, and still received the error.  I thought maybe I had broken something previously, as I've changed sizes, padding, etc a number of times.
      Something I'd also really like to be able to do is have it display HEX code, instead of RGB or CMYK, but none of my attempts have worked.
      I appreciate any help you all can give me!
      // Render Swatch Legend v1.1 -- CS, CS2, CS3, CS4, CS5
      //  This script will generate a legend of rectangles for every swatch in the main swatches palette.
      //  You can configure spacing and value display by configuring the variables at the top
      //  of the script.
      //   update: v1.1 now tests color brightness and renders a white label if the color is dark.
      // JS code (c) copyright: John Wundes ( john@wundes.com ) www.wundes.com
      // copyright full text here:  http://www.wundes.com/js4ai/copyright.txt
          doc = activeDocument,
          swatches = doc.swatches,
          cols = 20,
          displayAs = "CMYKColor",  //or "RGBColor"
          rectRef=null,
          textRectRef=null,
          textRef=null,
          rgbColor=null,
          w=150;
          h=100,
          h_pad = 10,
          v_pad = 10,
          t_h_pad = 10,
          t_v_pad = 10,
          x=null,
          y=null,
          black = new GrayColor(),
          white = new GrayColor()
          black.gray = 100;
          white.gray = 0;
      activeDocument.layers[0].locked= false;
      var newGroup = doc.groupItems.add();
      newGroup.name = "NewGroup";
      newGroup.move( doc, ElementPlacement.PLACEATBEGINNING );
      for(var c=0,len=swatches.length;c<len;c++)
              var swatchGroup = doc.groupItems.add();
              swatchGroup.name = swatches[c].name;
              x= (w+h_pad)*(c% cols);
              y=(h+v_pad)*(Math.floor((c+.01)/cols))*-1 ;
              rectRef = doc.pathItems.rectangle(y,x, w,h);
              rgbColor = swatches[c].color;
              rectRef.fillColor = rgbColor;
              textRectRef =  doc.pathItems.rectangle(y- t_v_pad,x+ t_h_pad, w-(2*t_h_pad),h-(2*t_v_pad));
              textRef = doc.textFrames.areaText(textRectRef);
              textRef.contents = swatches[c].name+ "\r" + getColorValues(swatches[c].color) ;
              textRef.textRange.fillColor = is_dark(swatches[c].color)? white : black;
              rectRef.move( swatchGroup, ElementPlacement.PLACEATBEGINNING );
              textRef.move( swatchGroup, ElementPlacement.PLACEATBEGINNING );
              swatchGroup.move( newGroup, ElementPlacement.PLACEATEND );
      function getColorValues(color)
              if(color.typename)
                  switch(color.typename)
                      case "CMYKColor":
                          if(displayAs == "CMYKColor"){
                              return ([Math.floor(color.cyan),Math.floor(color.magenta),Math.floor(color.yellow),Math.floor(co lor.black)]);}
                          else
                              color.typename="RGBColor";
                              return  [Math.floor(color.red),Math.floor(color.green),Math.floor(color.blue)] ;
                      case "RGBColor":
                              return rgb2cmyk(Math.floor(color.red),Math.floor(color.green),Math.floor(color.blue));
                         }else
                      case "GrayColor":
                              return rgb2cmyk(Math.floor(color.gray),Math.floor(color.gray),Math.floor(color.gray));
                          }else{
                              return [Math.floor(color.gray),Math.floor(color.gray),Math.floor(color.gray)];
                      case "SpotColor":
                          return getColorValues(color.spot.color);
          return "Non Standard Color Type";
      function rgb2cmyk (r,g,b) {
      var computedC = 0;
      var computedM = 0;
      var computedY = 0;
      var computedK = 0;
      //remove spaces from input RGB values, convert to int
      var r = parseInt( (''+r).replace(/\s/g,''),10 );
      var g = parseInt( (''+g).replace(/\s/g,''),10 );
      var b = parseInt( (''+b).replace(/\s/g,''),10 );
      if ( r==null || g==null || b==null ||
           isNaN(r) || isNaN(g)|| isNaN(b) )
         alert ('Please enter numeric RGB values!');
         return;
      if (r<0 || g<0 || b<0 || r>255 || g>255 || b>255) {
         alert ('RGB values must be in the range 0 to 255.');
         return;
      // BLACK
      if (r==0 && g==0 && b==0) {
        computedK = 1;
        return [0,0,0,1];
      computedC = 1 - (r/255);
      computedM = 1 - (g/255);
      computedY = 1 - (b/255);
      var minCMY = Math.min(computedC,
                    Math.min(computedM,computedY));
      computedC = (computedC - minCMY) / (1 - minCMY) ;
      computedM = (computedM - minCMY) / (1 - minCMY) ;
      computedY = (computedY - minCMY) / (1 - minCMY) ;
      computedK = minCMY;
      return [Math.floor(computedC*100),Math.floor(computedM*100),Math.floor(computedY*100),Math.floor (computedK*100)];
      function is_dark(color){
             if(color.typename)
                      case "CMYKColor":
                          return (color.black>50 || (color.cyan>50 &&  color.magenta>50)) ? true : false;
                      case "RGBColor":
                          return (color.red<100  && color.green<100 ) ? true : false;
                      case "GrayColor":
                          return color.gray > 50 ? true : false;
                      case "SpotColor":
                          return is_dark(color.spot.color);
                      return false;
        • 1. Re: RenderSwatchLegend
          Silly-V Adobe Community Professional
          If you are able to, try converting your artwork to process color, then running the script. Even if you want to keep your spot colors on your artwork, you can still make a copy of the artwork, use flatten transparency (with no preserve spot colors) to convert the art to process, run the script and then delete the copy.
