7 Replies Latest reply on Oct 15, 2017 3:00 PM by kglad
    A button's "down" and "hit" state includes changes to other buttons
    ks67641067
      Hi there -
      I thought I remembered a simple way to cause one button to change other buttons' down and hit states - but I can't seem to make it work easily. I have a series of buttons on the stage: button A, B, C, D, and so on. I want to, effectively, link multiple buttons. So if I hit Button A, I want Buttons C, D, and Q to change their states to their hit states. If I roll over button A, I want those buttons to change to their rollover states.
      Is there a simple way to get that done?
      Thank you in advance for any help you can offer!
        • 1. Re: A button's "down" and "hit" state includes changes to other buttons
          simple buttons have upState,downState and overState properties you can use to change a button's display.
          • 2. Re: A button's "down" and "hit" state includes changes to other buttons
            ks67641067 Level 1
            Thank you! Yes, I understand how to make one button look different in up, down and over states. But my question is how I can make one button make another button's state change as well as its own.
            • 3. Re: A button's "down" and "hit" state includes changes to other buttons
              again, use those button states.  eg,
              var buttonA:Array=[you buttons];
              var buttonStateA:Array=[];
              for(var i:int=0i<buttonA.length;i++){
              buttonStateA.push([buttonA[i].upState,buttonA[i].overState,buttonA[i].downState]);  // maintains a record of states of all buttons
              buttonA[i].addEventListener(MouseEvent.MOUSE_OVER,ovefF);
              function overF(e:MouseEvent):void{
              for(var i:int=0;i<buttonA.length,i++){
              if(i!=buttonA.indexOf(e.currentTarget)){
              buttonA[i].upState = buttonA[i].overState;  // if that's what you want
              • 4. Re: A button's "down" and "hit" state includes changes to other buttons
                ks67641067 Level 1
                Ohhh - I misunderstood; thank you.
                I'm pathetic with scripting. Let's say I have two buttons - one is called NameButton, and the other is called NameText. I want an action (hover, click, hit) to be mirrored between the two. If I hover over NameButton, I want NameText to show its hover state too, and vice versa. If I hit NameText, I want NameButton to act as if it were hit as well. I know I've butchered yourcode to an embarrassing degree - would you be willing to show me the correct syntax for that intended experience?
                var buttonName: Array = Name Buttons;
                var buttonStateNameButton: Array = [NameButton, NameText];
                for (var i: int = 0i < NameButton.length; i++) {
                buttonStateNameButton.push([NameButton[i].upState, NameButton[i].overState, NameButton[i].downState]); // maintains a record of states of all buttons
                buttonStateNameText.push([NameText[i].upState, NameText[i].overState, NameText[i].downState]
                NameButton[i].addEventListener(MouseEvent.MOUSE_OVER, ovefF);
                NameText[i].addEventListener(MouseEvent.MOUSE_OVER, ovefF);
                function overF(e: MouseEvent): void {
                for (var i: int = 0; i < Name Button.length, i++) {
                if (i != NameButton.indexOf(e.currentTarget)) {
                NameButton[i].overState = NameText[i].overState; // if that's what you want
                NameText[i].overState = NameText[i].overState; // if that's what you want
                • 5. Re: A button's "down" and "hit" state includes changes to other buttons
                  var buttonA:Array=[namgeButton,nameText];
                  buttonA[i].addEventListener(MouseEvent.MOUSE_OUT,outF);
                  buttonA[i].upState = buttonStateA[i][1];  // if that's what you want
                  function outF(e:MouseEvent):void{
                  buttonA[i].upState = buttonStateA[i][0];  // if that's what you want
                  • 6. Re: A button's "down" and "hit" state includes changes to other buttons
                    ks67641067 Level 1
                    Thank you! I will give that a shot.
