5 Replies Latest reply on Oct 16, 2017 4:33 AM by azisher
    Expand stroke/create outline of multiple SVG
    azisher Level 1
      Hello everyone, I have more than a thousand SVG icons but unfortunately all SVG are in stroke like this image below:
      and this one below is what I'm looking for:
      I've tried Illustrator batch action with this step: Select - All on active artboard - Object - Expand - Save.
      BUT I need to confirm (click OK) each time expand windows pop-up appear, and it's take a lot of times.
      Is there any script to replace this action without clicking any pop-up window?
      Thanks.
        • 1. Re: Expand stroke/create outline of multiple SVG
          itsBenMason Level 2
          Hellos,
          For this you can use the executeMenuCommand to run the expand options like so:
          app.executeMenuCommand("selectall");
          app.executeMenuCommand ('Live Outline Stroke');
          app.executeMenuCommand ('expandStyle');
          Full script that will open all SVG files within a folder then save to an output folder within the original folder.
          //Change this to your AI files folder (Be sure to end with a /)
          var location = "/Path/To/Folder/Containing/SVG/Files/";
          function getFiles() {
            var folder = new Folder(location);
            if (folder.exists) {
              return folder.getFiles("*.svg");
            } else {
              alert("Unable to find SVG Files Folder");
          function openFiles(files) {
            var documents = [];
            for (var i = 0; i < files.length; i++) {
              var file = files[i];
              documents.push(app.open(file));
            return documents;
          function saveFile(destination, name, document) {
            var folder = new Folder(destination);
            if (!folder.exists) folder.create();
            var destFile = new File(destination + name);
            document.saveAs(destFile);
           * Run script
           openAndExpand();
          function openAndExpand() {
            try {
              var files = getFiles();
              if (files.length > 0) {
                //Open Each File
                var documents = openFiles(files);
                if (documents.length > 0) {
                  //Expand Each File and Save
                  for (var i = 0; i < documents.length; i++) {
                    var document = documents[i];
                    document.activate();
                    expandFile();
                    saveFile(location + "/output/", document.name, document);
                  //Close All Documents
                      documents[i].close();
            } catch(e) {
              alert("Error Processing:");
              alert(e);
          function expandFile() {
          • 2. Re: Expand stroke/create outline of multiple SVG
            azisher Level 1
            Hi Ben, thank you for your help.
            Tested your script but its save as Ai not SVG, is there any way to keep the file as SVG?
            • 3. Re: Expand stroke/create outline of multiple SVG
              itsBenMason Level 2
              Whoops, give us a moment ill change to SVG saving
              • 4. Re: Expand stroke/create outline of multiple SVG
                itsBenMason Level 2
                  var options = new ExportOptionsSVG();
                  document.exportFile(destFile, ExportType.SVG, options);
                Replace the old save function with this one and should save the files as SVG again.
                (Apologies, had activeDocument and not document though should work the same)
                • 5. Re: Expand stroke/create outline of multiple SVG
                  azisher Level 1
                  Thank you so much, you saved my life!
