1 Reply Latest reply on Oct 19, 2017 10:55 AM by kerrishotts
    Cordova version update issue
    haritha krishnar65523315
      I have my application which is build in Cordova version 3,  Now I want to add google Analytics inside it. As the Cordova version got updated, I have updated all the plugins which I have used in my application. But after building while running the application, a black blank screen is displaying after the splash screen. I am not getting any errors in the console also.
      When I searched, this issue may happen due to splash screen. But I am getting the splash screen and after 2 secs it is hiding as usual. I tried all the possibilities , but the result was same.
      These are the versions which I am currently working on:
          ionic (Ionic CLI) : 3.13.0
          cordova (Cordova CLI) : 7.1.0
          Gulp CLI              : CLI version 3.9.1 Local version 3.9.1
          Cordova Platforms : android 6.3.0 ios 4.3.1
          Ionic Framework   : ionic1 1.0.0-beta.8
          ios-deploy : 1.9.2
          Node       : v6.11.4
          npm        : 3.10.10
          OS         : macOS Sierra
          Xcode      : Xcode 8.3.2 Build version 8E2002
      Can anyone help on this. Thanks in advance.
        • 1. Re: Cordova version update issue
          kerrishotts Adobe Employee
          Most likely a JavaScript syntax or logic error (when updating plugins, it's possible that the API will have changed. If your code isn't ready for that, things will break.)
          When you mention "console", are you referring to the JavaScript console (in Safari) or Xcode's console?
          Also -- your iOS platform version is a bit out of date. 4.5.2 is the latest.
