• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
brush overlapping with settings all correct
New Here ,
Oct 16, 2017 Oct 16, 2017
Hi I am having issues with my brushes continuously overlapping even when I have changed the brush settings to multiply and have the layer settings to multiply. I am trying to paint in a solid color and it is showing up as such :
I am using kyle watercolor brushes if that is any help and I am using a Huion tablet. As far as I know everything is updated and I don't see why that would be an issue with this situation. I like the texture of the brush but I want a solid color without value changing overlap. Your help is appreciated!!
Views
787
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Contributor ,
The watercolor brushed base is transparent not a solid color when you have splash brushed it can be solid. I advise you to use the brushes as it is and then duplicate it and you can see it the result that you want.
Votes
Translate
Translate
Report
Report
Community Expert ,
You have flow jitter set to pen pressure.
You'll get full coverage if you use full pressure
Votes
Translate
Translate
Report
Report
New Here ,
I turned off the opacity and flow jitter and it still is overlapping.
Votes
Translate
Translate
Report
Report
Community Expert ,
Are you painting on the same layer or the layer above your original brush strokes?
Michelle
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 17, 2017 Oct 17, 2017
LATEST
Is it off in the brush panel and in the Options Bar. The options bar will turn pressure control for flow/opacity back on again
Dave
Votes
Translate
Translate
Report
Report
