• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Run gulp from Air Application
Community Beginner ,
Oct 17, 2017 Oct 17, 2017
I am trying to run a gulp task from my air application on mac using NativeProcess class. It works like charm when compiling and running from intellij but not when compiling a dmg with extendedDesktop profile. It seems to be the problem that air cannot find gulp, at least this is the response (command not found).
When trying to get down to the problem i found out, that air doesnt recognize the /usr folder where gulp is installed (even when installed global via "sudo npm install gulp-cli -g". It's not possibly to locate gulp installation.
Again: common commands like "zip" or something already work with the compiled dmg file. it's just i can't make gulp to be found by the compiled app. same code run by intellij working.
Anyone any idea?
Thank you!
TOPICS
Development
Views
335
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
what is the command-line you use in AIR ?
how did you install node/npm and gulp ? homebrew ? macport ? other?
try to run those commands from AIR native process and see their output
"which gulp"
"command -v 'gulp'"
try also
"printenv"
and look in PATH=...
see if the path where gulp is installed is there
also if some of those commands output to stderr instead of stdout
you will need to redirect stderr to stdout
for example:
java -version
will output to stderr
you would need to do
java -version 2>&1
so the stderr is redirected to stdout
some things to explore
1. "gulp"
if command not found
then use "which gulp" or "command -v gulp"
to find the full path, for ex it could returns "/usr/bin/gulp"
2. then try to call gulp with the fullpath eg. "/usr/bin/gulp"
3. the problem could be node
in gulp/gulp.js at master · gulpjs/gulp · GitHub
you can see "#!/usr/bin/env node"
maybe gulp can not find "node" with the "env" command
4. the problem could be your $PATH
if gulp is installed in a local directory like "/opt/local/bin"
maybe this path is not in the PATH environnement variable
and then even if gulp is installed it would not be found
If all that still does not work you could explore the idea
of converting gulp to an executable with such tools
as nexe, node-compile, node-compiler, etc.
and then distribute the exe within the AIR app
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
You are possibly pointing to a shortcut and not the real app.
Votes
Translate
Translate
Report
Report
