2 Replies Latest reply on Feb 12, 2018 9:51 AM by deelbe
    Need script to batch convert vector .eps to .svg images script
    pascalclijsters
      I'm looking for a script/program that if you run it, all the .eps files in a folder will batch convert to a .svg.
      I have already found a script to convert .eps to .png-24, but don't know how to edit it to export to .svg.
      Pascal
      .eps to .png-24 script
      /********************************************************** ADOBE SYSTEMS INCORPORATED  Copyright 2005 Adobe Systems Incorporated  All Rights Reserved  NOTICE:  Adobe permits you to use, modify, and  distribute this file in accordance with the terms of the Adobe license agreement accompanying it.   If you have received this file from a source  other than Adobe, then your use, modification, or distribution of it requires the prior  written permission of Adobe.  *********************************************************/    /********************************************************** Save as PDFs.js DESCRIPTION This sample gets files specified by the user from the  selected folder and batch processes them and saves them  as PDFs in the user desired destination with the same  file name. **********************************************************/    // Main Code [Execution of script begins here]    // uncomment to suppress Illustrator warning dialogs  // app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;    var destFolder, sourceFolder, files, fileType, sourceDoc, targetFile, pngExportOpts;    // Select the source folder.  sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files you want to convert to PNG', '~' );    // If a valid folder is selected  if ( sourceFolder != null )  {      files = new Array();      fileType = prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );            // Get all files matching the pattern      files = sourceFolder.getFiles( fileType );            if ( files.length > 0 )      {          // Get the destination to save the files          destFolder = Folder.selectDialog( 'Select the folder where you want to save the converted PNG files.', '~' );          for ( i = 0; i < files.length; i++ )          {              sourceDoc = app.open(files[i]); // returns the document object                                                    // Call function getNewName to get the name and file to save the pdf              targetFile = getNewName();                            // Call function getPNGOptions get the PNGExportOptions for the files              pngExportOpts = getPNGOptions();                            // Export as PNG              sourceDoc.exportFile( targetFile, ExportType.PNG24, pngExportOpts );                            sourceDoc.close(SaveOptions.DONOTSAVECHANGES);          }          alert( 'Files are saved as PNG in ' + destFolder );      }      else      {          alert( 'No matching files found' );      }  }          /********************************************************* getNewName: Function to get the new file name. The primary name is the same as the source file. **********************************************************/    function getNewName()  {      var ext, docName, newName, saveInFile, docName;      docName = sourceDoc.name;      ext = '.png'; // new extension for png file      newName = "";                for ( var i = 0 ; docName[i] != "." ; i++ )      {          newName += docName[i];      }      newName += ext; // full png name of the file            // Create a file object to save the png      saveInFile = new File( destFolder + '/' + newName );              return saveInFile;  }          /********************************************************* getPNGOptions: Function to set the PNG saving options of the  files using the PDFSaveOptions object. **********************************************************/    function getPNGOptions()  {            // Create the PDFSaveOptions object to set the PDF options      var pngExportOpts = new ExportOptionsPNG24();                        // Setting PNGExportOptions properties. Please see the JavaScript Reference      // for a description of these properties.      // Add more properties here if you like      pngExportOpts.antiAliasing = true;      pngExportOpts.artBoardClipping = true;      pngExportOpts.horizontalScale = 100.0;      //pngExportOpts.matte = true;      //pngExportOpts.matteColor = 0, 0, 0;      pngExportOpts.saveAsHTML = false;      pngExportOpts.transparency = true;      pngExportOpts.verticalScale = 100.0;        return pngExportOpts;  }
        • 1. Re: Need script to batch convert vector .eps to .svg images script
          itsBenMason Level 2
          Not tested but should work, just changed the PNG options to SVG options and also changed extension to .svg
          All Rights Reserved
          Save as PDFs.js
          DESCRIPTION
          as SVGs in the user desired destination with the same
          file name.
                      // Create SVG Options Object
                      var options = new ExportOptionsSVG();
                      // Export as SVG
                      sourceDoc.exportFile( targetFile, ExportType.SVG, options );
                  alert( 'Files are saved as SVG in ' + destFolder );
              else
              ext = '.svg'; // new extension for sag file
              newName = "";
              newName += ext; // full sag name of the file
              // Create a file object to save the sag
              return saveInFile;
          • 2. Re: Need script to batch convert vector .eps to .svg images script
            deelbe Level 1
            Thanks for posting! I tweaked the script to only export .eps to .svg. Also fixed the 'PNG' file type in the dialog and added a 'var' to the i = 0 in the first for loop. I tested the script and it works.
            DESCRIPTION
            file name.
            sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files you want to convert to SVG', '~' );
                //fileType = prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );
                fileType = '*.eps';
                    for (var i = 0; i < files.length; i++ )
                        // Call function getNewName to get the name and file to save the svg
                        // Export as SVG
                    alert( 'Files are saved as UNCOMPRESSED SVG in ' + destFolder );
                else
                ext = '.svg'; // new extension for svg file
                newName = "";
                newName += ext; // full svg name of the file
                // Create a file object to save the svg
                return saveInFile;
