1 Reply Latest reply on May 22, 2008 10:53 AM by Applied CD
    secondary monitor
    Level 7
      Hi
      my application experiences some problems on computer with 2 monitors
      1) It is started in primary monitor, but user can move the window to
      secondary monitor. And when it jumps from one movie to another - the window
      jumps automatically again to primary monitor
      2) when I change resolution for primary monitor, resolution on secondary
      monitor is also changed, but to some other values as on primary monitors
      Any suggestions?
      Any help will be appreciated
      game_dev
        • 1. Re: secondary monitor
          Applied CD Level 1
          On your first issue, are you sure it only happens on multiple monitors? At least in MX04 and earlier if the user moved the stage anywhere (even just a new location on the primary monitor), subsequent movies did not track the new location. The attached code is old but should fix the problem, simply place in a movie script in every movie or attach to every movie through a shared cast.
