• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
FDK custom dialog scrolling list item limit
New Here ,
Oct 18, 2017 Oct 18, 2017
FM is crashing when I am population a list of items in a scrolling list display. I think it is due to the number of items, around 1000 or more lines and it crashes, otherwise it works fine.
Is there a hard limit on the number of items displayed? Can it be overridden or is there an alternative similar display method?
TOPICS
Scripting
Views
331
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
I would not be surprised if there was some kind of limit to that number. I would not think a list item box with that number of entries would be good user interface design in the first place. What is the use case?
Votes
Translate
Translate
Report
Report
Mentor ,
I have never seen any limit described in the documentation, but it certainly seems that there must be a limit. 1000 sounds like a reasonable limit to me, because we are talking about a UI widget. As a user, I would not want to scroll through 1000 items. There are many tricks you could use to streamline the list and dynamically repopulate based on user behavior, but I will readily admit that the FDK UI tools are rudimentary. Like Jang suggests, perhaps if we knew more about your use case we could offer better suggestions.
Russ
Votes
Translate
Translate
Report
Report
New Here ,
You are both right, it is displaying a list of image references grouped by document. I would probably need to work more and if the list is too long display only the references for one document and have another list of documents to select from. As you say this will then repopulate the list with a fewer number of items. Thanks.
Votes
Translate
Translate
Report
Report
Mentor ,
Oct 19, 2017 Oct 19, 2017
Here's another idea to help your users, not necessarily related to the original problem of exceeding FM capabilities... You might consider adding a field for a basic text filter. For example, you could enter "diagram" and the list shortens to any filename/path/whatever that only contains that substring. I did that for a list of targets in a custom cross-reference dialog and it really improved the ability to find the desired target.
Russ
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
What do you want to happen when your user selects an image from the list?
Votes
Translate
Translate
Report
Report
