• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Relink pictures
Community Beginner ,
Oct 18, 2017 Oct 18, 2017
We have several Illustrator files with huge embedded pictures (.jpg and .eps). What I need to do is to relink those pictures to some .psd files with the same file name. Doing this manually takes ages so I’m trying to write a script, but being a complete beginner I have no clue about how to do that.
Basically loop through the pictures and relink all of them to a psd file that has the same file name.
Example: picture.jpg -> relink to /images/picture.psd
I hope someone can help me out! Thanks.
TOPICS
Scripting
Views
588
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Valorous Hero ,
Try to run this little snippet on a test file which contains a couple .jpg and .eps links.. and let's see if it works!
#target illustrator
function test(){
  var doc = app.activeDocument;
  for(var i=0; i<doc.placedItems.length; i++){
       doc.placedItems.file = File(doc.placedItems.file.replace(/(\.jpg|\.eps)/, ".psd"));
test();
Votes
Translate
Translate
Report
Report
Thank you!
I will test it Friday when I get back to work.
Cheers
Votes
Translate
Translate
Report
Report
Oct 20, 2017 Oct 20, 2017
Hello,
I tried to use the code but nothing happens, so I tried to add an alert to see what's actually going on; the alert(doc.placedItems.length) returns 0.
function test(){
  alert('hello');
  alert(doc.placedItems.length);
       alert(i);
test();
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Oh sorry, I didn't read carefully: you said the images you have are embedded.
Here's what you can do: open up your variables panel and do this for each of your images: click image, then use the Lego®-looking button at the bottom of the Variables panel to 'make content dynamic'. After all your images are made into variables, use the camera button at the top to capture a single dataset. Now, export an XML file using the 'save variables library' menu item in the Variables panel's fly-out menu. At this point you can open up the XML file and use text-replace to change all '.jpg' to .psd and so forth. Then when you're done text-replacing, save this XML file and re-import it inside of your Illustrator document. Now, if it does not happen instantly, selecting the first dataset after this new import will change all the image variables to get images from the new paths- relinking the files to .psd.
Let me know if you have questions.
Votes
Translate
Translate
Report
Report
Hello,
Thank you for your reply.
I tried to follow your instructions but after I select the image and bring up the variables panel, the icon for 'make content dynamic' it's greyed out, the other button 'make visibility dynamic' it's working.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Oct 21, 2017 Oct 21, 2017
DOH! Once again, I did the same thing last year! ( File Location of Pasted Image  )
Okay, try to run this script and see if it's going to work:
#target illustrator
function test(){
var errorFiles = [];
var newPath = "~/Desktop"; // change this to your path
  var thisRaster, newPlaced, newFilePath;
  for (var i = doc.rasterItems.length - 1; i > -1; i--) {
  thisRaster = doc.rasterItems;
  try {
  if(thisRaster.hasOwnProperty('file') && thisRaster.file != ""){
  newFilePath = newPath + "/" + decodeURI(thisRaster.file.name).replace(/(\.jpg|\.eps|\.png)/, ".psd");
  if(!File(newFilePath).exists){
  throw new Error("File not found");
  newPlaced = doc.placedItems.add();
  newPlaced.file = ( File(File(newFilePath).fsName) );
  newPlaced.move(thisRaster, ElementPlacement.PLACEBEFORE);
  newPlaced.top = thisRaster.top;
  newPlaced.left = thisRaster.left;
  newPlaced.width = thisRaster.width;
  newPlaced.height = thisRaster.height;
  thisRaster.remove();
  } catch(e) {
  errorFiles.push(decodeURI(thisRaster.file.name));
  if(errorFiles.length > 0){
  alert("The following files had problems:\r" + errorFiles.join("\n"));
test();
Votes
Translate
Translate
Report
Report
Oct 24, 2017 Oct 24, 2017
I really appreciate your help, but unfortunately after playing with the script for a while I had to give up and start doing the job manually because of a lack of time.
All the best.
Rob
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
Oh no! Sorry I couldn't help you.
Votes
Translate
Translate
Report
Report
