11 Replies Latest reply on Oct 23, 2017 8:39 AM by AssembledVS
    Image different outside of Photoshop if "proof colors" is unchecked
    AssembledVS
      Photoshop CC 2017
      When working with a particularly dark image, I noticed something that I have not noticed before - my images are a bit different in the Photoshop environment than anywhere else, including in Windows Photos, in my browser, and most importantly, in my game development engine, Unity.
      Getting my image in Photoshop to look exactly the same as it does in any other environment requires me to do two things:
      1. View -> Proof Setup -> Monitor RGB
      2. Checking View -> Proof Colors to ON
      My color settings are already North America General Purpose 2, sRGB IEC61966-2.1. I don't think I've ever touched this default setting. I also noticed that my Proof Setup setting was set to Working CMYK, but because Proof Colors was always unchecked, it did not seem to make a difference. Is this the default setting?
      From what I've read, it seems like I should NOT be working with Proof Colors on. But this setting is what gets my Photoshop image in Photoshop to look like its target environment, which is in Unity, online, just within Windows, etc.
      What am I doing wrong?
      Here are my settings below:
        • 1. Re: Image different outside of Photoshop if "proof colors" is unchecked
          D Fosse Adobe Community Professional & MVP
          This is the difference between color managed and not. Photoshop uses the monitor profile to correct for your monitor - the others do not and just pass the numbers straight through. Photoshop displays the file correctly, the others incorrectly.
          Proofing to Monitor RGB disables display color management.
          You just have to decide whether correct or consistent is more important.
          • 2. Re: Image different outside of Photoshop if "proof colors" is unchecked
            AssembledVS Level 1
            Thank you for the explanation.
            I want to work in Photoshop in the same color environment that everyone else will see. My game screenshots, the game itself - those assets, within the browser or within Unity, should look the same in Photoshop as they do everywhere else.
            What do I have to do to make my Photoshop color environment be the same as all the other environments?
            Is it checking Proof Colors to ON? Though I've heard that you should not be working that way. Furthermore, there is no way to make it the default setting; every document that is opened will have it off by default. Another suggestion that Adobe themselves believe that this is not the right way of working in Photoshop.
            EDIT: It seems like changing RGB in Edit -> Color Settings -> Settings to Monitor RGB makes this color environment work program-wide. My images now look in Photoshop the way they do everywhere else. Is it recommended to work in this mode? What are the downsides?
            • 3. Re: Image different outside of Photoshop if "proof colors" is unchecked
              Well, you just dumbed down Photoshop to just another application without color management. That's what Monitor RGB does: it disables color management. If you're happy with that, fine, but you need to be aware of what's happening here. Photoshop no longer displays correctly.
              Color management was invented to solve this exact problem: to see exactly what others see. There's no other way to achieve that. But only some applications do it.
              • 4. Re: Image different outside of Photoshop if "proof colors" is unchecked
                AssembledVS Level 1
                Perhaps I'm missing something here so please help me understand:
                "Color management was invented to solve this exact problem: to see exactly what others see."
                The entire issue is that I'm not seeing what other people see when I'm working with my image in Photoshop. On two different monitors and on my phone, my image outside of Photoshop looks different than the image in Photoshop. I understand that Photoshop displays the image "correctly," but what good is that when I'm the only one seeing it?
                • 5. Re: Image different outside of Photoshop if "proof colors" is unchecked
                  Other people with Photoshop will see what you see.
                  The other apps without color management are all over the map and always will be, nothing you can do about that.
                  • 6. Re: Image different outside of Photoshop if "proof colors" is unchecked
                    mglush Adobe Community Professional
                    I have a quick question for you. Does Unity -- the program you are working in -- give you any guidance as to what color space you should be working in?
                    And just one other bit of information -- proof colors deals specifically for proofing for PRINT. You are correct--you should not be working in Proof Colors. Since you are working with output directly for monitors or electronic devices, you want to stay in sRGB and not CMYK.
                    Michelle
                    • 7. Re: Image different outside of Photoshop if "proof colors" is unchecked
                      Yes, normally, that's the main use for it. But print profiles can be RGB - all inkjet profiles are RGB.
                      And then there is one very special case, proofing to Monitor RGB. It is the equivalent of assigning the monitor profile to your document - that's what it simulates.
                      What happens then is that in the normal display color management chain, the source profile is the same as the destination profile. Since both profiles are the same, nothing happens. Nothing changes from document RGB to monitor RGB, no correction for the monitor. And that, ladies and gentlemen, is of course the definition of no color management.
                      So proofing to Monitor RGB can be used to preview how it will look in an application without color management. As long as it's perfectly clear that this applies only to that actual system and that actual monitor. Everywhere else is completely to the wind.
                      • 8. Re: Image different outside of Photoshop if "proof colors" is unchecked
                        AssembledVS Level 1
                        I get that. But my users will not be viewing the game or the images of the game from Photoshop.
                        Related question - if most of my users will not be viewing from a color managed environment (online, in-game, etc.), does it make sense to NOT work in a color managed environment? My monitor profile is what I typically see in games, in my browser, etc., and so do the vast majority of users. (My other monitors and phone's images look much more like my work monitor's profile's image than the Photoshop sRGB profile version of the image). Would it not make sense to work in this profile, then?
                        Michelle - I do not see any documentation related to color management in Unity. As far as I can tell, pretty much all games are not color managed regardless of the engine and use the color profile set in the OS. I've actually always noticed that if I open up a game screenshot in Photoshop, it looks a bit different than what I remember seeing in the game.
                        • 9. Re: Image different outside of Photoshop if "proof colors" is unchecked
                          You're assuming that "no color management" means one single thing. It doesn't! No color management looks like one thing on your laptop, like something else entirely on the desktop system in your study, and you might no even recognize it on your tablet or phone. No color management is entirely unpredictable!
                          This is the problem that color management solves. But the application has to support it, and few do.
                          No, they don't. An application without color management doesn't know what a profile is. It takes the original RGB numbers in the file, and throws them directly at the screen. No questions asked. The rest is up to how close that particular display's native color space is to the document color space.
                          A color managed application converts from document color space to monitor color space - on the fly, as you work. This preserves color appearance by recalculating the numbers in the file before they hit the screen. This is a standard profile conversion just like any other profile conversion.
                          • 10. Re: Image different outside of Photoshop if "proof colors" is unchecked
                            Summed up: the only reference you have is how the file is supposed to look. A color managed application will show you this, assuming you have a valid monitor profile.
                            Outside a color managed environment it's a lottery. You're assuming you can predict that, but you can't. How it looks on your monitor is no indication whatsoever of how it will look elsewhere.
                            • 11. Re: Image different outside of Photoshop if "proof colors" is unchecked
                              AssembledVS Level 1
                              OK, thanks. I think that I'll just stick with using the sRGB profile while creating assets in Photoshop and not worry too much about what others see.
