Bonjour,
Je viens de télécharger After Effects CC 2018, a chaque démarrage, j'obtiens un crash et ce message s'affcihe ?!!
Je suis sur un macbook Pro (fin 2013) Intel Core I7
Merci de votre aide !!
Hi JuliaDesign,
Looks like trouble with your BCC plug-ins. Remove them or update them. Then you should be clear of this crash.
Kevin
Moving to After Effects
Pardon, mon francais est mal.
Vous avez mis a jour vos driveres GPU?
Aussi, je trouve ca pour une vieux version
The workaround given is to disable the gpu sniffer until the fix is issued.
1. In the After Effects CC folder, Ctrl-click on Adobe After Effects CC.app
2. Choose "Show Package Contents" from the context menu.
3. Open the Contents > MacOS folder, look for "sniffer"
4. Keep that file, but rename it by placing a tilde in from of sniffer: ~sniffer
5. Close the finder and AE CC should launch normally.
Thanks ! but sorry, it didn't work…
here the full report of the crash :
Process: | After Effects [7486] |
Path: | /Applications/Adobe After Effects CC 2018/Adobe After Effects CC 2018.app/Contents/MacOS/After Effects |
Identifier: | com.adobe.AfterEffects |
Version: | 15.0 (15.0) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | After Effects [7486] |
User ID: | 501 |
Date/Time: | 2017-10-23 23:30:33.037 +0200 |
OS Version: | Mac OS X 10.11.6 (15G1611) |
Report Version: | 11 |
Anonymous UUID: | BA8C9C42-0B8B-8D10-296D-7EAC29C105D4 |
Time Awake Since Boot: 43000 seconds
System Integrity Protection: enabled
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x000000000000003c |
Exception Note: | EXC_CORPSE_NOTIFY |
VM Regions Near 0x3c:
__TEXT | 0000000100c41000-0000000100c48000 [ 28K] r-x/rwx SM=COW /Applications/Adobe After Effects CC 2018/Adobe After Effects CC 2018.app/Contents/MacOS/After Effects |
Global Trace Buffer (reverse chronological seconds):
2.270885 | CFNetwork | 0x00007fff8e02cdb3 TCP Conn 0x7ffbca6245e0 SSL Handshake DONE | |
2.579185 | CFNetwork | 0x00007fff8e02cc8f TCP Conn 0x7ffbca6245e0 starting SSL negotiation | |
2.579421 | CFNetwork | 0x00007fff8e02b659 TCP Conn 0x7ffbca6245e0 complete. fd: 18, err: 0 | |
2.579525 | CFNetwork | 0x00007fff8e0b9f33 TCP Conn 0x7ffbca6245e0 event 1. err: 0 | |
2.735469 | CFNetwork | 0x00007fff8e02a92b TCP Conn 0x7ffbca6245e0 started | |
2.946491 | CFNetwork | 0x00007fff8e02cdb3 TCP Conn 0x7ffbcce259c0 SSL Handshake DONE | |
3.436048 | CFNetwork | 0x00007fff8e02cc8f TCP Conn 0x7ffbcce259c0 starting SSL negotiation | |
3.436291 | CFNetwork | 0x00007fff8e02b659 TCP Conn 0x7ffbcce259c0 complete. fd: 18, err: 0 | |
3.436393 | CFNetwork | 0x00007fff8e0b9f33 TCP Conn 0x7ffbcce259c0 event 1. err: 0 | |
3.596726 | CFNetwork | 0x00007fff8e02a92b TCP Conn 0x7ffbcce259c0 started |
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation | 0x00007fff8d0ba104 CFBundleGetFunctionPointerForName + 36 |
1 com.BorisFX.BCC Fast Film Glow Dissolve PrTr X 0x0000000134b25589 xGPUFilterEntry + 105
2 com.adobe.VideoFilterHost.framework 0x000000011577915a ML::GPUVideoFilterEntry::LoadFilter(int (*)(unsigned int, int*, int, piSuites*, PrGPUFilter*, PrGPUFilterInfo*), std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int*, int, piSuites*, PrGPUFilter*, PrGPUFilterInfo*) + 186
3 com.adobe.VideoFilterHost.framework 0x0000000115778f92 ML::GPUVideoFilterModule::LoadModule(int, int*) + 210
4 com.adobe.VideoFilterHost.framework 0x0000000115777f75 ML::GPUVideoFilterModule::Create(ASL::InterfaceRef<ML::IPlugin, ML::IPlugin> const&, ASL::InterfaceRef<ML::IPiPL, ML::IPiPL> const&, int*) + 133
5 com.adobe.VideoFilterHost.framework 0x0000000115777e1e ML::GPUVideoFilterFactory::CreateUnknown(ASL::InterfaceRef<ML::IPlugin, ML::IPlugin>, std::__1::vector<ASL::InterfaceRef<ML::IPiPL, ML::IPiPL>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IPiPL, ML::IPiPL> > >, int, int&) + 110
6 com.adobe.PluginSupport.framework 0x0000000114dc631c ML::(anonymous namespace)::AddPlugin(ML::PluginEntry const&, bool&, bool) + 8796
7 com.adobe.PluginSupport.framework 0x0000000114dc0a73 ML::(anonymous namespace)::LoadPluginList(ML::PluginNameList const&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 1875
8 com.adobe.PluginSupport.framework 0x0000000114dbf23f ML::LoadPlugins(std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, bool) + 4463
9 com.adobe.PluginSupport.framework 0x0000000114de53b9 ML::PluginSupport::LoadAllPlugins(std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&) + 1401
10 PREM.dylib | 0x0000000105500956 ae::prem::MediaCoreData::MediaCoreData(char const*, bool, PF_World*, bool, bool, bool, bool) + 2166 | |
11 PREM.dylib | 0x0000000105504be7 ae::prem::MediaCoreData::MediaCoreData(char const*, bool, PF_World*, bool, bool, bool, bool) + 39 | |
12 PREM.dylib | 0x0000000105509014 PREM_Birth + 692 |
13 com.adobe.AfterEffectsLib.framework 0x0000000100f3112b InitPREM(bool, bool, bool, bool, bool, bool) + 827
14 com.adobe.AfterEffectsLib.framework 0x0000000100e984eb CEggApp::BirthPkgGrpD(aelib::InitIterator&, bool) + 107
15 com.adobe.AfterEffectsLib.framework 0x0000000100e9ef05 CEggApp::IEggApp(aelib::InitIterator&, bool, bool) + 5797
16 com.adobe.AfterEffectsLib.framework 0x0000000100e66092 CEggApp::CEggApp(aelib::InitIterator&, bool, bool, int, boost::shared_ptr<StartupTimeTelemetry>) + 1682
17 com.adobe.AfterEffectsLib.framework 0x0000000100eb6506 MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int) + 886
18 com.adobe.AfterEffectsLib.framework 0x0000000100eb617a EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 58
19 com.adobe.AfterEffects | 0x0000000100c44383 main + 2483 | |
20 com.adobe.AfterEffects | 0x0000000100c43864 start + 52 |
Hi JuliaDesign,
Kevin
Hi Kevin,
It works ! Thank you very much !
Julia
