6 Replies Latest reply on Jun 18, 2008 3:57 PM by kglad
    Problem Loading Variables and comparing loaded var with if statement
    Alfarovive Level 1
      I am loading variable strings from a textfile using:
      loadVariables ("Map/lotes.txt", loteData);
      The text file has the strings in the following format:
      &lote1=H506,01,El Gaucho,Restaurante
      Then I am splitting the string using:
      lote = loteData .split(",");
      lote[0] should be H506
      lote[1] should be 01
      lote[2] should be El Gaucho
      lote[3] should be Restaurante
      I have already have instances loaded in the movie named the same as a concatanation of lote[0] and lote[1] nested inside another clip named the same as lote[0] all inside other clips the path is:
      _root.Map.Map[lote[0]][lote[0]+[lote[1]]]
      I am atatching a variable loteType to the instance :
      _root.Map.Map[lote[0]][lote[0]+[lote[1]]].loteType = lote[3];
      But when I want to check if the variable matches a test string I do not get a match:
      if (_root.Map.Map[lote[0]][lote[0]+[lote[1]]].loteType == "Restaurante") {
      trace("This is a Restaurant");}
      Whats wrong? Is it that the variable is not declared as a character string? I cant figure it out. I also am having
