6 Replies Latest reply on Oct 20, 2017 6:12 AM by subieguy2
    Save .eps as .eps (overwrite saving changes)
    subieguy2 Level 1
      Ok so I have been working on a tool that will automate some file changes for me. Thank you to itsBenMason it has been coming along awesome. So now I have 2 tasks left. Task one....
      I am searching folders for any files that contain _matte.eps
      var files = dir.getFiles("*_matte.eps");
      var folderFiles = folder.getFiles("*_matte.eps");
      How can I make this look for *_matte.eps as well as *_gloss.eps?
      Task two....
      These are already .eps files. How do I just save the file overwriting the .eps that I have made changes to?
      I have tried both of the following formats:
      doc.save(SaveOptions.SAVECHANGES);
      doc.save();
      Both of those save a .ai file with the same file name as the .eps
      Here is the code in it's entirety... Any help would be appreciated!
      // Establish variable to count changes made
      var changesMade = 0;
      // Display the GUI
      try {
          var gui = createGUI();
          gui.show();
      } catch (e) {
          alert(e);
      // Go through subfolders as well
      function getSubFolders(dir, collection) {
          if (collection === undefined) collection = [];
          var files = dir.getFiles();
          if (files.length > 0) {
              for (var i = 0; i < files.length; i++) {
                  var file = files[i];
                  if (file.constructor == Folder && file.name !== "") {
                      collection.push(file);
                      getSubFolders(file, collection);
                      alert(file.name);
          return collection;
      // Panel fields and information
      function createGUI() {
          var gui = new Window("dialog", "CMYK Correction Tool");
          gui.alignChilren = ["fill", "fill"];
          gui.orientation = "column";
          var panelGroup = createGroup(gui, "row");
          // Wrong CMYK
          var wrongPanel = createPanel(panelGroup, "Wrong CMYK Values");
          var wrongCyan = createTextField(wrongPanel, "Cyan Value:", "");
          var wrongMagenta = createTextField(wrongPanel, "Magenta Value:", "");
          var wrongYellow = createTextField(wrongPanel, "Yellow Value:", "");
          var wrongBlack = createTextField(wrongPanel, "Black Value:", "");
          // Right CMYK
          var rightPanel = createPanel(panelGroup, "Right CMYK Values");
          var rightCyan = createTextField(rightPanel, "Cyan Value:", "");
          var rightMagenta = createTextField(rightPanel, "Magenta Value:", "");
          var rightYellow = createTextField(rightPanel, "Yellow Value:", "");
          var rightBlack = createTextField(rightPanel, "Black Value:", "");
          var buttons = createGroup(gui, "row");
          // Confirm button
          var confirmBtn = createButton(buttons, "Confirm", function() {
              try {
                  // Select folder that contains your files
                  var dir = Folder.selectDialog("Select your file directory...");
                  if (dir != null) {
                      //Get all sub folders
                      var folders = getSubFolders(dir, []);
                      //Loop over folders
                      for (var i = 0; i < folders.length; i++) {
                          var folder = folders[i];
                          // Only look for files with the .ai extension and collect them
                          for (var j = 0; j < folderFiles.length; j++) {
                              files.push(folderFiles[j]);
                      //Loop over files
                              // alert(files.length);
                              if (file.constructor == File) {
                                  var doc = app.open(file);
                                  // Collect all of the open document pathItems
                                  var allPaths = doc.pathItems;
                                  // Loop through all of the open document pathItems
                                  for (var z = 0; z < allPaths.length; z++) {
                                      // Only look for a specific CMYK fillColor
                                      if (Math.round(allPaths[z].fillColor.cyan) == getText(wrongCyan) &&
                                          Math.round(allPaths[z].fillColor.magenta) == getText(wrongMagenta) &&
                                          Math.round(allPaths[z].fillColor.yellow) == getText(wrongYellow) &&
                                          Math.round(allPaths[z].fillColor.black) == getText(wrongBlack)) {
                                      if (Math.round(allPaths[z].fillColor.cyan).toFixed(2) == Math.round(getText(wrongCyan)).toFixed(2) &&
                                      Math.round(allPaths[z].fillColor.magenta).toFixed(2) == Math.round(getText(wrongMagenta)).toFixed(2) &&
                                      Math.round(allPaths[z].fillColor.yellow).toFixed(2) == Math.round(getText(wrongYellow)).toFixed(2) &&
                                      Math.round(allPaths[z].fillColor.black).toFixed(2) == Math.round(getText(wrongBlack)).toFixed(2)) {
                                          // Change the fillColor properties
                                          allPaths[z].fillColor.cyan = getText(rightCyan);
                                          allPaths[z].fillColor.magenta = getText(rightMagenta);
                                          allPaths[z].fillColor.yellow = getText(rightYellow);
                                          allPaths[z].fillColor.black = getText(rightBlack);
                                          changesMade++;
                                          doc.save();
                                  // Close the document
                                  doc.close();
              gui.close();
              } catch (e) {
                  alert(e);
          // Cancel Button
          var cancelBtn = createButton(buttons, "Cancel", function() {
              gui.close();
          return gui;
      // Function to collect user input
      function getText(field) {
          return field.text !== undefined ? field.text : "";
      // Function to build panel
      function createPanel(parent, title) {
          // Create Panel
          var panel = parent.add("panel", undefined, title);
          panel.orientation = "column";
          // Return panel
          return panel;
      // Function to create button
      function createButton(parent, title, onClick) {
          // Create Button
          var button = parent.add("button", undefined, title);
          if (onClick !== undefined) button.onClick = onClick;
          // Return button
          return button;
      // Function to create field in panel
      function createTextField(parent, title, content) {
          // Create a group for title and field
          var group = createGroup(parent, "column");
          group.alignChildren = 'left';
          // Create title
          var title = group.add("statictext", undefined, title);
          var field = group.add("edittext", undefined, content);
          field.preferredSize = [200, 23];
          // Return the field as its all you'll use
          return field;
      // Function to organize the panel layout
      function createGroup(parent, orientation) {
          // Create Group
          var group = parent.add("group");
          group.orientation = orientation;
          // Return Group
          return group;
      alert(changesMade + " color changes were made.");
        • 1. Re: Save .eps as .eps (overwrite saving changes)
          itsBenMason Level 2
          Try this
          function saveEPS(doc, file) {
            //Create save options
            var options = new EPSSaveOptions();
            //Save
            doc.saveAs(file, options);
          function getFiles(folder) {
            return folder.getFiles(/(_matte|_gloss)\.eps/i);
          getFiles(new Folder("Path/To/Files/"));
          • 2. Re: Save .eps as .eps (overwrite saving changes)
            subieguy2 Level 1
            so here is the error I get when I run the following script.... what am I doing wrong?? and it isn't saving over the eps file.
            // Display the GUI
            try {
                gui.show();
            } catch (e) {
                alert(e);
                            alert(file.name);
                return collection;
                // Wrong CMYK
                // Right CMYK
                // Confirm button
                    try {
                        if (dir != null) {
                            getFiles();
                            //var files = dir.getFiles("*_matte.eps");
                            //Loop over folders
                                // var folderFiles = folder.getFiles("*_matte.eps");
                            //Loop over files
                                                changesMade++;
                                                //doc.save();
                                                saveEPS();
                                        doc.close();
                        gui.close();
                    } catch (e) {
                        alert(e);
                // Cancel Button
                    gui.close();
                return gui;
                // Create Panel
                // Return panel
                return panel;
                // Create Button
                // Return button
                return button;
                // Create title
                return field;
                // Create Group
                // Return Group
                return group;
                //Save
            //getFiles(new Folder("Path/To/Files/"));
            • 3. Re: Save .eps as .eps (overwrite saving changes)
              itsBenMason Level 2
              change
              saveEPS();
              to saveEPS(doc, file);
              • 5. Re: Save .eps as .eps (overwrite saving changes)
                itsBenMason Level 2
                in the save EPS function add
                alert(doc);
                alert(file);
                and see what it outputs.
                Not able to open atom or anything at the minute so can only guide you through until i can.
                Just noticed you have this
                getFiles();
                but you are not setting any var with the returned files
                and also the getFiles() function takes a folder object
                • 6. Re: Save .eps as .eps (overwrite saving changes)
                  subieguy2 Level 1
                  Ok. No worries. Again I appreciate all your help. I am not a programmer... I kinda sorta get by with basics. But I am drowning here in all your efficient functions lol.
                  So what I am working toward is allowing the user to put in the correct and incorrect values.
                  If the file contains the name _gloss.eps it gets the following CMYK values (which I want the user to be able to type in).
                  CORRECT values for CMYK gloss:
                  CMYK Gloss: C 0 M 100 Y 100 K 35
                  If the file contains the name _matte.eps it gets the following CMYK values (which I want the user to be able to type in).
                  CORRECT values for CMYK matte:
                  CMYK Matte: C 0 M 100 Y 100 K 33
                  No matter if it contains _matte.eps or _gloss.eps the incorrect values are the same (which I want the user to be able to type in).
                  INCORRECT values for CMYK gloss AND CMYK matte:
                  C 22.98 M 100 Y 100 K 17.84
                  All files I need to edit will be .eps. I want the changes to be saved to the edited .eps file (with no new file created).
                  All of this I would like to apply to a selected folder and all subfolder/subfiles.
                  What we have here is really close...but it is getting over my head with all the functions.
