2 Replies Latest reply on Dec 6, 2017 5:36 AM by prashantk75375230
    Recommendation Feed Dry-run possibility?
    Runal.Trivedi Level 4
      I wanted to check if there is a way to make sure that generated feed (CSV) is Target compliant, some kind of dry-run functionality?
      Sometimes I see Target takes hours to a complete day to index/not-index the feed, which is fine, but not always helpful when you are running on tight deadline or want to make sure that your minor code amendments did not break the entire feed.
      Is there any external tool or process to make sure and test pass the generated feed for recommendations along with its data?
