• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CC 2018 starts infinitely crashing once you paste Mocha Pro Shape data to the clipboard
Explorer ,
Oct 19, 2017 Oct 19, 2017
I just updated thinking my simple Mocha Pro project should be fine... but whenever I'm in the Mocha Pro interface and track a mask and then copy that shape data to the clipboard, as soon as I close the interface and am back in AE, without doing anything (not even time enough to paste the data as a Mocha mask), the program shuts off with a big error window.
Then even if I simply try to open the app without selecting the project that crashed, as in, try to open a new blank project, it crashes immediately after loading.
I had to restart to be able to run AE again.
(partial) Error message below:
Process:               After Effects [2618]
Path:                  /Applications/Adobe After Effects CC 2018/Adobe After Effects CC 2018.app/Contents/MacOS/After Effects
Identifier:            com.adobe.AfterEffects
Version:               15.0 (15.0)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           After Effects [2618]
User ID:               501
Date/Time:             2017-10-19 20:10:50.173 -0400
OS Version:            Mac OS X 10.12.6 (16G29)
Report Version:        12
Anonymous UUID:        77E7E006-D5B0-898E-4D19-0ECB05B538E8
Time Awake Since Boot: 1200 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0:
    __TEXT                 0000000106be0000-0000000106be7000 [   28K] r-x/rwx SM=COW  /Applications/Adobe After Effects CC 2018/Adobe After Effects CC 2018.app/Contents/MacOS/After Effects
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   BEE.dylib                     0x00000001084b3740 std::__1::enable_if<__is_forward_iterator<std::__1::__wrap_iter<unsigned char*> >::value, std::__1::__wrap_iter<unsigned char*> >::type std::__1::basic_string<unsigned char, std::__1::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> >::insert<std::__1::__wrap_iter<unsigned char*> >(std::__1::__wrap_iter<unsigned char const*>, std::__1::__wrap_iter<unsigned char*>, std::__1::__wrap_iter<unsigned char*>) + 1072
1   BEE.dylib                     0x00000001084ace43 BEEp_ConvertKeyframeScrap(short, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 9075
2   BEE.dylib                     0x00000001084afe61 BEE_ConvertScrapFromPublic(short, dvaui::datatransfer::OS_ReceiveDataBase*, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 545
3   com.adobe.AfterEffectsLib.framework 0x0000000107472cb4 CEggApp::ParseClipboard(unsigned char) + 1412
4   com.adobe.AfterEffectsLib.framework 0x000000010747ad9e CEggApp::DoCommand(int) + 8446
5   com.adobe.AfterEffectsLib.framework 0x00000001075fc5ae CDirTabPanel::DoCommand(int) + 206
Views
3.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hello,
According to mocha Pro spec, it supports Adobe CC2014 - CC2017. It would be better to contact Boris FX support team directly.
https://borisfx.com/products/mocha/#specs
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 24, 2017 Oct 24, 2017
To be clear, the new Adobe After Effects CC 2018 release causes a crash when you copy Mocha shape data to clipboard, than go back to AE.  This is happens with all versions of Mocha.
This crash issue only occurs with "Mocha shape data" on the clip board, not tracking data which does work properly from Mocha AE and Mocha Pro.
The workaround: If you own Mocha Pro and want to convert Mocha shape data to AE masks, do not use the clipboard. Use the "Convert AE Masks" button found on the Mocha Pro plug-in interface.
If you do not own Mocha Pro and wish to use Mocha AE for masking, you will need to go back to CC 2017 until Adobe fixes this issue.
The Adobe AE team and Mocha team are in touch and aware of the issue. Sorry for any inconvenience.
- Mocha Team at Boris FX
Votes
Translate
Translate
Report
Report
Explorer ,
I was always using the "export shape data" button on the mocha interface in each instance when AE crashed. I'm not familiar with a "convert AE masks" button. Where is that?
Votes
Translate
Translate
Report
Report
New Here ,
Oct 25, 2017 Oct 25, 2017
Yes, I have the same issue. My clunky workaround is to install an older After Effects, then output a luma mask, then bring that into the new After Effects.
What is this Mocha Plugin Convert AE Masks button you speak of???
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 30, 2017 Oct 30, 2017
Same problem for me !
Votes
Translate
Translate
Report
Report
LEGEND ,
workarounds for this issue you might consider:
Re: After Effects crash when coppied shape mask data from Mocha AE
Votes
Translate
Translate
Report
Report
New Here ,
Nov 20, 2017 Nov 20, 2017
Does anybody know when the fix will be available?
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 19, 2018 Jan 19, 2018
crickets chirping. still waiting.
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 23, 2018 Jan 23, 2018
LATEST
The After Effects update that came out last night (might take up to 24 hours to propagate to Adobe's servers around the world) fixes this issue.
Votes
Translate
Translate
Report
Report
