1 Reply Latest reply on Oct 19, 2017 11:21 PM by SuperMerlin
    [artLayer].id returns undefined on windows, works fine on mac
    jonnyr39056025 Level 1
      I've written a script that at some point calls .id on an artlayer to get that layer's unique ID to reference later. I've developed this on a mac and it works perfectly on a mac. However, I need this to be cross platform, and on windows calling .id returns undefined instead of the unique ID, throwing an error. I'm running this on Photoshop CS6.
      I need the ID as I want to select specific layers, and want to be sure the correct layers are selected even if they share a name with another layer, or are nested inside a layerSet.
      My script's below, does anyone know why the behaviour is different here, or know of a fix, workaround or different approach I can take to get the same results?
      #target photoshop
      // SETUP //////////////
      // Save the current preferences
      var startRulerUnits = app.preferences.rulerUnits;
      var startTypeUnits = app.preferences.typeUnits;
      var startDisplayDialogs = app.displayDialogs;
      // Set Adobe Photoshop CS6 to use pixels and display no dialogs
      app.preferences.rulerUnits = Units.PIXELS;
      app.preferences.typeUnits = TypeUnits.PIXELS;
      app.displayDialogs = DialogModes.NO;
      // FUNCTIONS //////////
      // returns currently selected layers as an array
      function getSelectedLayers() {
          var idGrp = stringIDToTypeID( "groupLayersEvent" );
          var descGrp = new ActionDescriptor();
          var refGrp = new ActionReference();
          refGrp.putEnumerated(charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ),charIDToTypeID( "Trgt" ));
          descGrp.putReference(charIDToTypeID( "null" ), refGrp );
          executeAction( idGrp, descGrp, DialogModes.ALL );
          var resultLayers = new Array();
          for (var ix = 0; ix < app.activeDocument.activeLayer.layers.length; ix++) {
              resultLayers.push(app.activeDocument.activeLayer.layers[ix]);
          var id8 = charIDToTypeID( "slct" );
          var desc5 = new ActionDescriptor();
          var id9 = charIDToTypeID( "null" );
          var ref2 = new ActionReference();
          var id10 = charIDToTypeID( "HstS" );
          var id11 = charIDToTypeID( "Ordn" );
          var id12 = charIDToTypeID( "Prvs" );
          ref2.putEnumerated( id10, id11, id12 );
          desc5.putReference( id9, ref2 );
          executeAction( id8, desc5, DialogModes.NO );
          return resultLayers;
      // returns bounds of layer
      function visibleBounds(layer) {
          doc.activeLayer = layer;
          return doc.activeLayer.bounds;
      // difference between two numbers plus boolean for determining direction
      function difference(num1, num2) {
          if (num1 > num2) {
              return [num1 - num2, false];
          } else {
              return [num2 - num1, true];
      function selectLayerById(id, add){
          var ref = new ActionReference();
              ref.putIdentifier(charIDToTypeID('Lyr '), id);
          var desc = new ActionDescriptor();
              desc.putReference(charIDToTypeID("null"), ref );
          if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
          desc.putBoolean( charIDToTypeID( "MkVs" ), false );
          try{
              executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
          }catch(e){}
      // THE MAIN BIT ///////
      var doc = app.activeDocument;
      var slctdLyrs = getSelectedLayers();
      function main(){
          var lyrA = slctdLyrs[0];
          var lyrB = slctdLyrs[1];
          var aID = slctdLyrs[0].id;
          var bID = slctdLyrs[1].id;
          var lyrABounds = visibleBounds(lyrA);
          var lyrBBounds = visibleBounds(lyrB);
          var posA = [ lyrABounds[0], lyrABounds[1] ]; //position of top left corner
          var posB = [ lyrBBounds[0], lyrBBounds[1] ]; //position of top left corner
          var deltaX = difference(posA[0], posB[0]); //difference in x axis
          var deltaY = difference(posA[1], posB[1]);//difference in y axis
          if (deltaX[1] == false) { // translates layers in x axis
              lyrA.translate((deltaX[0] * -1), 0);
              lyrB.translate(deltaX[0], 0);
          } else {
              lyrA.translate(deltaX[0], 0);
              lyrB.translate((deltaX[0] * -1), 0);
          if (deltaY[1] == false) { // translates layers in y axis
              lyrA.translate(0, (deltaY[0] * -1));
              lyrB.translate(0, deltaY[0]);
          } else {
              lyrA.translate(0, deltaY[0]);
              lyrB.translate(0, (deltaY[0] * -1));
          //reselect 1st layer
          selectLayerById(aID, false);
          //reselect 2nd layer
          selectLayerById(bID, true);
      // EXECUTE IT /////////
      if (slctdLyrs.length == 2) {
          try {
              doc.suspendHistory("Swap Layers", "main()" );
          catch (e){
              alert(e);
      } else {
          alert("Ouch!\nSelect two layers to swap their positions!");
      // REVERT /////////////
      //restore preferences
      app.preferences.rulerUnits = startRulerUnits;
      app.preferences.typeUnits = startTypeUnits;
      app.displayDialogs = startDisplayDialogs;
