Hi All,
Scratching my head on this one, trying to make a hot button on my carousel but not working on a mobile phone but on desktop it does.
any help will be appreciated
here is an link to index please view it on mobile to see what I'm trying to explain
Thanks All like always!
Buttons are not working for me on desktop either.
It's not a good idea to have links on top of carousel pagers. It's going to be a conflict for many users.
Instead of having image in the background, I would keep images in the foreground HTML and link the image to its target page.
An example. Pinebrook Vacation Rentals
The Bootstrap default Carousel works fine on mobile devices. Try replacing your CSS link with this one and test it to see if your Carousel behaves better.
<!-- Latest compiled and minified Bootstrap CSS-->
<link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css" integrity="sha384-BVYiiSIFeK1dGmJRAkycuHAHRg32OmUcww7on3RYdg4Va+PmSTsz/K68vbdEjh4u" crossorigin="anonymous">
PS. I'm not lovin' that fixed BACK TO THE TOP button on mobile devices. I think it's better to ditch it -- at least on small devices where it just gets in the way.
Thanks Nancy for the info I will take A look at it.
Hi Nancy,
I do have the bootstrap.min file I just renamed it to ciss but not sure why is acting goofy when placing a button inside carouse.
thanks again Nancy
Will
Good day Nancy, that didn't work actually when I insert the cdn it messed up my whole css so didn't do anything.
The default code works fine in mobile viewports.
Copy & paste this code into a new, blank document and test it.
<!doctype html>
<html lang="en-US">
<head>
<meta charset="utf-8">
<title>Bootstrap 3.7 Carousel</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<style>
.center-block {float:none}
</style>
</head>
<body>
<div class="container-fluid">
<div class="row">
<div class="col-md-10 center-block text-center">
<h1>Bootstrap 3.7 Default Carousel</h1>
</div>
<!--begin Bootstrap Carousel-->
<div id="myCarousel" class="carousel slide" data-ride="carousel" data-interval="5200">
<!-- Indicators -->
<ol class="carousel-indicators">
<li data-target="#myCarousel" data-slide-to="0" class="active"></li>
<li data-target="#myCarousel" data-slide-to="1"></li>
<li data-target="#myCarousel" data-slide-to="2"></li>
<li data-target="#myCarousel" data-slide-to="3"></li>
</ol>
<!-- Wrapper for slides -->
<div class="carousel-inner" role="listbox">
<div class="item active">
<img src="https://placeimg.com/1180/400/arch/4" alt="...">
<div class="carousel-caption">
<h3>Heading 3</h3>
<p>Details....</p>
</div>
</div>
<div class="item">
<img src="https://placeimg.com/1180/400/arch/3" alt="...">
<h3>Heading 3</h3>
<p>Details....</p>
</div>
</div>
<div class="item">
<img src="https://placeimg.com/1180/400/arch/2" alt="...">
<h3>Heading 3</h3>
<p>Details....</p>
</div>
</div>
<div class="item">
<img src="https://placeimg.com/1180/400/arch/1" alt="...">
<h3>Heading 3</h3>
<p>Details....</p>
</div>
</div>
<!--end active-->
</div>
<!-- Left and right controls -->
<a class="left carousel-control" href="#myCarousel" role="button" data-slide="prev">
<span class="glyphicon glyphicon-chevron-left" aria-hidden="true"></span>
<span class="sr-only">Previous</span> </a> <a class="right carousel-control" href="#myCarousel" role="button" data-slide="next">
<span class="glyphicon glyphicon-chevron-right" aria-hidden="true"></span>
<span class="sr-only">Next</span> </a>
<!--end carousel-->
</div>
</div>
<div class="row">
<div class="col-md-10 center-block">
<p>Lorem ipsum dolor sit amet, consectetur adipisicing elit. Esse quae placeat doloribus earum, aliquam, quibusdam dicta, pariatur nemo quo ut voluptates doloremque inventore. Magnam non iusto, deserunt ea! Necessitatibus, sequi.</p>
</div>
</div>
</div>
<!--latest jQuery 3-->
<script src="https://code.jquery.com/jquery-3.2.1.min.js" integrity="sha256-hwg4gsxgFZhOsEEamdOYGBf13FyQuiTwlAQgxVSNgt4=" crossorigin="anonymous"></script>
<!--Bootstrap-->
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js" integrity="sha384-Tc5IQib027qvyjSMfHjOMaLkfuWVxZxUPnCJA7l2mCWNIpG9mGCD8wGNIcPD7Txa" crossorigin="anonymous"></script>
</body>
</html>
I'm so sorry Nancy, for not explaining my self correctly what I mean the carousel works fine is the red hot button on the carousel that doesn't work on the mobile but on desktop it does. When you click on it on a desktop it goes to a page within the site but on a mobile it does nothing NO action comes out of it.
once again sorry for not explaining correctly
Thanks!
Thanks Nancy for all your help...
But I think is in the css or java because the carousel works great on IE but not on mobile devices and not on chrome... DAMN! I must of miss something here....
What is clearly stopping access to your link buttons is this 'overlay' <div> directly before your carousel indicators html. I don't know what it is or what it is for. If you remove it your button links will work. At the moment it is sitting over your buttons denying access to them.
<!-- Overlay -->
<div class="overlay"></div>
<!-- Indicators -->
<li data-target="#bs-carousel" data-slide-to="0" class="active"></li>
<li data-target="#bs-carousel" data-slide-to="1"></li>
<li data-target="#bs-carousel" data-slide-to="2"></li>
<li data-target="#bs-carousel" data-slide-to="3"></li>
<li data-target="#bs-carousel" data-slide-to="4"></li>
<li data-target="#bs-carousel" data-slide-to="5"></li>
<li data-target="#bs-carousel" data-slide-to="6"></li>
<li data-target="#bs-carousel" data-slide-to="7"></li>
</ol>
