• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Lightroom Classic: Export produce duplicates - Bug?
Explorer ,
Oct 19, 2017 Oct 19, 2017
my new Lightroom Classic does not work classic while exporting edited Raw Files to e.g. Jepegs in a subfolder:
In the export process (of course with the option "Add to this catalog" checked) the exported files get not reimported to the related folder until the "work bar" has already disappeared long ago. So very, very slowly and sometimes not completely.
If I redo the export process (with the identical settings) and the confirmed request to overwrite existing data, LR creates duplicates in the export folder. This is obviously a database error, because in the folder each exported pIcture exist physically only once (as it should) ...
Have I described this complicated enough? :-))
I have tried it with my existing (for LR Classic updated) catalog, as well as with a freshly produced new catalog.
I´ve deleted the LR Preferences Folder and deactiveated all Plug Ins... Still the same mistake.
I have this issue with lightroom classic on my Windows 10 machine.
And I just reproduced this bug with a fresh LR installation on my brandnew macbook pro with the latest OS updates.
Thanks for any Help, Kai
Views
2.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I've tested this in LR2015 and now in Classic.
2015 has the correct behaviour and classic matches what you've seen. IHMO this is a bug, and I'll create a report for it.
Sean McCormack. Author of 'Essential Development 3'. Magazine Writer. Former Official Fuji X-Photographer.
Votes
Translate
Translate
Report
Report
Community Beginner ,
I've had the exact same thing happen, with one image shown three times even. While I'm exporting jpegs to the same folder, I got strange duplicates sometimes. One thing that seemed to stop this behavior is to export but uncheck the "Add to stack" setting. Also, when exporting with that checked, the stacked number of images remains at 2, and does not increase to 3, for an original TIF (from a scanner, filename.tif) image, the edited TIF (filename-edit.tif), and exported JPG (filename-edit.jpg).
One of my subfolders got so confused with only 30 images showing multiple duplicates and an incorrect count of images in the folder that then I deleted them all just from the database, and reimported them in place. This then returned the correct count of images, without any stacking.
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 20, 2017 Oct 20, 2017
Hi Sean,
many thanks for your response. Glad to hear, that the error is not on my system.
But how is it going on now? Can you tell how long it will take to get an update?
Votes
Translate
Translate
Report
Report
Community Expert ,
Honestly, no idea.
Can you check in your folder (command R or Control R on PC) to see if the files are duplicated or is it just in the catalog?
Votes
Translate
Translate
Report
Report
Explorer ,
duplicates just in Lightroom.
Votes
Translate
Translate
Report
Report
Explorer ,
here i´ve recorded a little screencast to demonstrage my problem:
https://shared-assets.adobe.com/link/f8912c5c-7fa5-4fa3-6be0-8f0b6f02f379
Votes
Translate
Translate
Report
Report
Community Expert ,
That matches my experience and was included in my bug report.
Votes
Translate
Translate
Report
Report
Oct 23, 2017 Oct 23, 2017
Similar issue exporting image files (all types) to Microsoft OneDrive from LR Classic.  I have been attempting to export my picture files from Lightroom into Microsoft OneDrive to provide an additional back-up. This is a process that is generally slow and can be quite temperamental as others may have found. However since I upgraded to LR Classic it appears that a copy of every file exported is placed in the Pictures folder on my Mac. These files are not placed into any hierachy (all of my originals exist in my Dropbox folder organised into sub-folders by capture date).  I can only assume that LR creates a copy as part of the export process but then fails to delete that copy.
It took me a little while to work out where close to 100Gb of disck space had gone and a while longer to locate and delete the duplicates.
Votes
Translate
Translate
Report
Report
Oct 25, 2017 Oct 25, 2017
Same issue here, lightroom prompts to overwrite existing file and does on disk - but the catalog shows two images. If you try to 'Reveal' the duplicate image in finder, lightroom marks it as missing.
Also, anyone else having issues moving files in Classic? For example I moved some images into a subfolder and they just don't show up even though they have moved on disk. Even a sync doesn't bring them in. Capture.JPG
Restarting Lightroom made them show up.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 28, 2017 Oct 28, 2017
Put me down as a "Me Too."
I just did the Oct. 28, 2017, update to LR Classic hoping it would have fixed the bug, but I am still getting duplicates in the catalog when re-exporting images and using Overwrite.
Also, possibly for a different topic, I am not able to use LR's built-in merge to HDR function. It creates the preview, but upon choosing Merge it shows no progress in the Creating HDR bar at top left.
Votes
Translate
Translate
Report
Report
Nov 05, 2017 Nov 05, 2017
There is a work-around for this until adobe fixes it:
1. Firstly If you have made develop module changes to the files, make sure your metadata is saved.
2. Remove the offending images from your lightroom catalog (remove, not delete) and synchronise the folder to bring them back in.
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 16, 2022 Jul 16, 2022
LATEST
In July 2022 I continue to have the same problem. On export the latest version of Lightroom Classic saves a duplicate .jpg file in a separate folder it has created. Of course I can delete the unwanted folder and the images in it, but it is irritating, and one has to make sure that one is deleting the correct folder and not the images from Lightroom!
Votes
Translate
Translate
Report
Report
