1 Reply Latest reply on Oct 20, 2017 8:48 AM by hatstead
    New frames to PSE 11?
    niconist
      Is it possible to load new frames in this version, PSE 11?
      And how the loading should proceed in the program, PSE?
      - thanks a lot!
        • 1. Re: New frames to PSE 11?
          hatstead Adobe Community Professional
          I don't think that this is readily possible, but you can make your own frames. Try this:
          1. Open the picture file
          2. Go to Select>all
          3. Open a blank layer above the Background Layer (Layer 1)
          4. Go to Edit>Stroke(outline)Selection. Make  stroke large - try 25 px width. Position it inside. Color does not matter.
          5. Open the Effects palette and in the drop-down select Bevels. Use Scalloped Edges. Apply.
          6. Still on the Effects palettes, in the drop-down select Patters. Use Wood. Apply.
          7. On Layer 1 double click the f on the right to bring up the Style settings dialog. Use the slider to adjust the bevel to suit.
          8. Press CTRL+D to get rid of the marching ants.
