• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Is there any way to automatically update links in mobile / tablet versions of a site which point to other pages in the same site?
New Here ,
Oct 20, 2017 Oct 20, 2017
I have made a desktop version of a site containing close to a thousand links between pages (it is a website for an artist, so each image in each of the many, many galleries, has a right and a left arrow to navigate to the next or previous page).
On the desktop version, the hyperlinks all point to [Desktop] and I thought that when copying elements over to the tablet or phone versions, it would automatically point the links to the [Phone] or [Tablet] versions of the pages, but that is not the case: each link still points toward the Desktop pages.
Will tablet and mobile devices automatically redirect themselves to the correct versions of pages, is there a simple way to change all links in one go if I need to do so, or do I literally have to edit each link one by one? At least if I could access the html code I could find and replace '[Desktop]' with '[Phone]' to speed the process up!
The site was built on a template which does not work with breakpoints as it was designed with multiple versions in mind - scroll effects disappear if I add breakpoints, for instance,  so switching to a version with breakpoints instead of alternate versions is not an option here. Besides which I think my life would be in danger if I suggest to my partner that she has to start working on breakpoints all over again!!!
I've searched high and low for an answer to this question - the only instance I can find is an unanswered question in the forums from 2015 titled 'Hyperlinks not automatically adjusted for mobile'.
Any advice on how to swiftly get this working (or some reassurance that mobiles and tablets will ignore the '[Desktop]' part of the hyperlink and will just automatically load their versions of each page without wasting time loading the wrong one!) would be hugely appreciated!
Views
311
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Oct 20, 2017 Oct 20, 2017
Scroll effects do not disappear at all, if you add breakpoints.
There are two different kind of breakpoints – fluid width and fixed width breakpoints.
If you use fixed width breakpoints, scroll effects work quite properly.
You may have some issue only for your mobile section, where normall
Votes
Translate
Translate
Contributor ,
If you are using Alternate layout, you have to relink the elements to appropriate version.
To avoid that issue you can do it in responsive layout.
Toufic Nabi
Votes
Translate
Translate
Report
Report
New Here ,
So I literally have to click on each and every hyperlink and edit it to say 'Mobile' or 'Tablet' at the end? There's no 'replace all' function available?
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Sorry, there are no shortcut to do that. I would rather suggest you to switch to responsive layout and NO the scroll effect will not go away if you work in a fixed width breakpoint. Additionally you can delete the alternate layout for phone and tablet once you decide to work on responsive.
Toufic
Votes
Translate
Translate
Report
Report
LEGEND ,
You may have some issue only for your mobile section, where normally fluid width breakpoints are recommended.
But in your case (what we call a worst case scenario ), why not stick with fixed width breakpoints through the whole site?
If you pass us one page with one or two elements, we can check, if this is possible.
Just one desktop page with one gallery and one other element should be enough to check OR you check by yourself.
Best Regards,
Uwe
Votes
Translate
Translate
Report
Report
