4 Replies Latest reply on Jun 6, 2008 9:10 AM by Newsgroup_User
    External ActionScript (k)
    Level 7
      I have an external ActionScript file that I call in using #include
      It works well, but I would like to have several different scripts called
      in. I know I can make multiple .as files and call each individually.
      That'll work, but is kinda messy.
      Is there a way I can call separate parts of one .as file? So I can
      include several actions in one .as file and only call specific action?
      -Kirk
        • 1. Re: External ActionScript (k)
          Level 7
          Anybody?
          > -Kirk
          • 2. Re: External ActionScript (k)
            Bob Pierce Level 1
            If your .as file includes many functions you can call each one individually.
            • 3. Re: External ActionScript (k)
              Level 7
              Could you give an example of how I would write that syntax?
              I'm new to this, sorry.
              -Kirk
              • 4. Re: External ActionScript (k)
                Level 7
                Maybe this'll help:
                I did break the .as into two files, FadeIn.as and Fade.Out.as
                FadeIn.as is:
                // import tween classes
                import mx.transitions.Tween;
                import mx.transitions.easing.*;
                var Animation:Object;
                Animation = new Tween(this, "_alpha", Regular.easeInOut, 0, 100,
                _global.FadeInTime, true);
                Then on the MovieClips I put:
                onClipEvent (enterFrame) {
                //FadeIn ActionScript is stored in an external .as file
                #include "redheadActionScript/FadeIn.as"
                Works on the first clip, but not the second. I think it is because the
                #include is supposed to be done once.
                So then I thought I could somehow store this code in a variable, but
                that didn't work.
                Then I tried to do a global function, but that didn't work because it
                didn't like me calling the mx.transitions.Tween twice
                So basically, I have no idea what I am doing.
                -Kirk
                > -Kirk
                >> individually.
