• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
Photoshop CC 2018 IGNORES TABLET PROPERTIES
Explorer ,
Oct 20, 2017 Oct 20, 2017
I just updated Photoshop to the latest update ( 19.0 20170929.r.165 2017/09/29: 1138933  x64)
and it completely ignores the tablet properties such as:
a) Pen Pressure (the pen no longer have pen pressure, no matter if windows ink is turned on or of)
b) Screen Lock (the tablet should lock on Monitor 1 while using Photoshop, and it doesn't)
Every other software i'm using such as Clip studio Paint, zBrush and so on are working fine.
While photoshop completely ignores them.
The previous version used to work fine, but it's been overwritten by the new one without even asking.
The software, no matter the new features, has got worse with every update in terms of performance,
stability, and usability.
Introducing the standard windows Alt key behaviour was already driving me nuts.
i still have not tried the windows ink workaround
i hope this gets fixed TODAY because as it is, PS is useless to me, and i'll be moving to
any alternative available.
Views
122.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Oct 20, 2017 Oct 20, 2017
Update, the previous Win Ink workaround fix pen pressure and the screen lock
Trevor.Dennis  ha scritto
hansb90361119 wrote:
If you check the "use windows ink" for wacom intous 5 (most likly all of the models) you are getting a REALLY annoying lag with zoom and pen size adjuster etc. If you turn it off, it works perfect, but the downside is the pen pressure opacity don't work.
You've turned off Windows Ink, so without supplying an alternative, pen pressure is not going to work.  You have to enable Wi
Votes
Translate
Translate
Adobe
Explorer ,
You've turned off Windows Ink, so without supplying an alternative, pen pressure is not going to work.  You have to enable WinTab.
If Windows Ink is disabled
1. Create a file that contains instructions to revert to the WinTab functionality.
2. Create a text file in a text editor such as Notepad.
Type in the following lines:
# Use WinTab
UseSystemStylus 0
3. Save the file as a plain text file named PSUserConfig.txt
4. Put (copy) the file into the Photoshop settings folder: C:\Users\[User Name]\AppData\Roaming\Adobe\Adobe Photoshop CC 2015\Adobe Photoshop CC 2015 Settings\
5. Restart Photoshop and check the pen pressure and overall performance.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 24, 2017 Oct 24, 2017
This solution helped me. I have used this solution for very long time.
What is strange is that as far as i can member i didnt add this file to photoshop 2018 settings folder but the file was already there but with wrong extension. For some really strange reason the file was named as PSUserConfig.txt.txt
Votes
Translate
Translate
Report
Report
New Here ,
Nov 17, 2017 Nov 17, 2017
# Use WinTab
UseSystemStylus 0
This technically does work. But if you use Win10 it no longer has WinTab so use this instead:
     # Use Wacom Professional Service
     UseSystemStylus 0
I haven't tested it in 2018, but i had the same issue when I reverted to 2017 and updated my drivers. This SHOULD fix it
Votes
Translate
Translate
Report
Report
Nov 30, 2017 Nov 30, 2017
Seems like in CC 2018 this route is no longer valid:
So where should I put the the file?
Votes
Translate
Translate
Report
Report
Engaged ,
Is there no answer? None of this works for Win 10 / PS CC 2018
Adobe Community Expert
Votes
Translate
Translate
Report
Report
Engaged ,
Come on Adobe, this is your issue.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 11, 2018 Feb 11, 2018
thank you, this seems to have worked for me!
Votes
Translate
Translate
Report
Report
New Here ,
May 04, 2018 May 04, 2018
I tried the WinTab thing and it didn't work, but then I tried this and it did! (I have PS CC 2018 on Windows 10)
Thanks very much!!
Get your sh*t together, Microsoft + Adobe
Votes
Translate
Translate
Report
Report
New Here ,
May 23, 2018 May 23, 2018
Your suggestion totally got rid of the no pen pressure input issue from the newest update.
Thanks a lot!
This works on the the newest 2018 cc update, guys! Go for it, if you are suffering
Votes
Translate
Translate
Report
Report
New Here ,
Mar 24, 2020 Mar 24, 2020
I can confirm this is the only solution working on my windows 10 with a bamboo pen&touch, wintab is not working at all.
Still not fixed in 2020, so disappointing!
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 05, 2018 Apr 05, 2018
# Use WinTab
UseSystemStylus 0
Upgraded Photoshop once again.
had to follow these steps once again.
thought it my duty to bump it again, in case anybody else is having trouble and the windows ink trick isn't working for them either.
thanks again @guidos50720937
Votes
Translate
Translate
Report
Report
Participant ,
Apr 10, 2018 Apr 10, 2018
same problem
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 14, 2018 Apr 14, 2018
@andy.d.bell
Thank you this worked for me. Win 10 Psd 2018 on Cintiq after reinstalling my wacom driver and calibrating it.
Votes
Translate
Translate
Report
Report
Explorer ,
Interestingly enough right after I fixed the pen pressure issue with these steps
# Use WinTab
UseSystemStylus 0
I broke the pressure sensitivity again by reloading my old wacom prefs. Did the same trick again an now it is fixed. Again...
Votes
Translate
Translate
Report
Report
Explorer ,
I would like to RE Iterate that this TEXT quick FIX file only fixes part of the Issue. there are still a lot of other bugs involved. for instance, the Move tool is completely busted.
This is a Temporary band-aid to just be able to draw,paint.
I'm sorry but I get annoyed that
A: this needs to be fixed by someone... ADOBE, WACOM, or MICROSOFT.
B: It's handicapping me during my work day
C: I get annoyed that people keep recommending this stupid TXT code (wacom) WITHOUT REALLY TRYING IT! when It doesn't correct all of the issues that are occurring in Photoshop
Votes
Translate
Translate
Report
Report
New Here ,
Apr 11, 2018 Apr 11, 2018
Super fix, worked great! Do you know if you can use a similar fix for lighroom classic to fix pen pressure too?
Thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Apr 16, 2018 Apr 16, 2018
YESSSS great, thank you so much I was going crazy!!!  its working great now
Votes
Translate
Translate
Report
Report
New Here ,
Apr 20, 2018 Apr 20, 2018
THANK YOU!!!!
Votes
Translate
Translate
Report
Report
This worked perfectly for me.  The other issue I've been having is that when Windows ink was on, so I could leverage the pressure sensitivity, adjusting sliders with my pen (Wacom Intuos Pro) was dang near impossible with the lag.  This fix has finally enabled me to have my cake and eat it too   Thank you very much!  (BTW, my drives, wacom software and PS version are all current)
Votes
Translate
Translate
Report
Report
New Here ,
Apr 24, 2018 Apr 24, 2018
Thank you guidos! This fix worked for me and one of my co-workers who had the same issues with the latest Windows/Adobe updates clashing, and making work very difficult. We can finally get back to producing.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 17, 2018 Aug 17, 2018
THIS WORKED FOR ME!!!!!I have Windows 10 and Adobe Photoshop CC 2018 (17/08/2018)
1.- Quit Photoshop
2.- Open your Wacom Tablet Properties (from the start menu)
3.- Disable Windows Ink (From the photoshop tab. I have problems with chrome too so I disabled Windows Ink from tha main menu too)
4.- Create a text file in notepad with these lines:
UseSystemStylus 0
5.- Save it and put the file in this path:
C:\Users\YOUR_USERNAME\AppData\Roaming\Adobe\Adobe Photoshop CC 2018\Adobe Photoshop CC 2018 Settings
(ps: if you don't see app data, enable show hidden files)
6.- Open Photoshop and that's it
Votes
Translate
Translate
Report
Report
Hi guidos,
Thanks for reporting this issue.
Could you confirm if the workaround mentioned by TrevorDennis has been working fine for you?
We are investigating this issue and will get back with more updates.
Akash
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 23, 2017 Oct 23, 2017
Yes, it did, but the issue with windows ink is getting pretty boring since it comes back with every major Update
You should start considering the possibility of choosing the this option in the control panel (At Least)
BTW, the wacom drivers work PERFECTLY FINE with any other software, windows ink or not.
Votes
Translate
Translate
Report
Report
Hi, I was directed to this thread from another whose members are having a very strange glitch problem. Whenev we zoom in, then try to draw a vertical line, the stylus seens to grab the image and scroll. I’m using a Wacom Bamboo on a Surface Pro 3. It wasworking splendidly until yesterday and I don’t remember even updating manually but may have authorized a group update upon closing for the night.
Ive tried reinstalling old versions and now they all do it. I’ve cleared my preferences, disabled Windows Ink and even sent a mean text to my innocent neighbor,  just to blow off steam. (Kidding... because I have to or my frustration will wreck me).
please advise...as I have some deadlines I need to meet.
Thank you
Votes
Translate
Translate
Report
Report
