2 Replies Latest reply on May 22, 2008 10:10 AM by eLearningDeveloper
    all buttons lock up and do not respond
    eLearningDeveloper Level 1
      I am developing a tabbed-dialog box with multiple tabs. The piece is a single movie clip in a larger application, with different frames containing the graphic backgrounds for each tab. Textfields are placed on the backgrounds dynamically when the swf starts; the user clicks on a tab and sees the tab contents.
      When testing it, and I clicked in a text area and switched tabs, for some reason, no buttons react to being pressed anywhere, in or out of the dialog, and the app has to be closed down. Setting the textfields to "selectable=false" fixed this with blank textfields. However, when I created text links and placed them on a dialog panel, and click a link, then switch tabs, same problem.
      Thank you.
