18 Replies Latest reply on Oct 27, 2017 1:07 PM by Silly-V
    What's New in Illustrator Scripting CC2018
    CarlosCanto Adobe Community Professional & MVP
      CC2018
      New Class
      Asset
      Adobe Illustrator 22 Type Library
      An (exportable) asset.
      Properties
      Asset.assetID  (Read Only)
      Data Type: Int32
      The UID for the asset which is unique within a document.
      Asset.assetName
      Data Type: string
      Name of the asset.
      Asset.parent  (Read Only)
      Data Type: Object
      The object's container.
      Asset.typename  (Read Only)
      Data Type: string
      The class name of the object.
      Methods
      Asset.getNormalizedName (): string
      Gets the normalized name without special characters, such that it can be used as a file name.
      Asset.remove ()
      Deletes this object.
      Asset.removeAll ()
      Deletes all elements.
      New Collection
      Assets
      A collection of assets.
      Properties
      Assets.length  (Read Only)
      Data Type: int
      Number of elements in the collection.
      Assets.parent  (Read Only)
      Data Type: Object
      Assets.typename  (Read Only)
      Data Type: string
      Methods
      Assets.add (sourceArt:any): Asset
      Creates an asset from the given art(s)
      sourceArt: Data Type: any
      The page item(s) to apply to.
      Assets.addFromSelection (): Asset
      Creates an asset from the selected arts.
      Assets.getByID (assetID: Int32 ): Asset
      Gets the asset with the specified AssetID.
      assetID: Data Type: Int32
      The UID of the asset.
      Assets.getByName (name: string ): Asset
      Get the first element in the collection with the provided name.
      name: Data Type: string
      Assets.remove (assetID: Int32 )
      Deletes the asset with specified id.
      UID of the asset to be deleted.
      Assets.removeAll ()
      Application Class
      New Method
      Application.getIsFileOpen (filePath: string ): Boolean
      Returns if the specified filePath is open.
      filePath: Data Type: string
      The filePath to be checked.
      Document Class
      New Method
      Document.exportForScreens (exportFolder: File , exportFormat: ExportForScreensType , options:any, itemToExport: ExportForScreensItemToExport , fileNamePrefix: string )
      Export the specified document/asset(s)/artboard(s)
      exportFolder: Data Type: File
      The folder where the exported documents/assets/artboards are saved.
      exportFormat: Data Type: ExportForScreensType
      The file type in which the document is exported.
      options (optional): Data Type: any
      Options for the file type specified.
      itemToExport (optional): Data Type: ExportForScreensItemToExport
      What to export.
      fileNamePrefix (optional): Data Type: string
      String prepended to each file name.
      DocumentPreset Class
      New Properties
      DocumentPreset.documentBleedOffset
      Data Type: Rect
      Document bleed offset rect.
      DocumentPreset.documentBleedLink
      Data Type: Boolean , Default Value: true
      Document link for bleed values.
      TextRange Class
      New Properties
      TextRange.start
      Data Type: Int32
      Start index of the text range.
      TextRange.end
      Data Type: Int32
      End index of the text range.
      New Methods
      TextRange.getParagraphLength (): Int32
      Get the length of the first paragraph.
      TextRange.getTextRunLength (): Int32
      Get the length of the first text run.
      CharacterAttributes Class
      New Properties
      CharacterAttributes.kana
      Data Type: Boolean
      Does the Japanese OpenType support kana?
      CharacterAttributes.ruby
      Data Type: Boolean
      Does the Japanese OpenType support ruby?
      CharacterAttributes.kashidas
      Data Type: KashidasType
      Kashidas attribute.
      CharacterAttributes.dirOverride
      Data Type: DirOverrideType
      Direction override attribute.
      CharacterAttributes.digitSet
      Data Type: DigitSetType
      Digit set attribute.
      CharacterAttributes.diacVPos
      Data Type: DiacVPosType
      Diacritics positioning attribute.
      CharacterAttributes.diacXOffset
      Data Type: number
      Diacritics x offset attribute.
      CharacterAttributes.diacYOffset
      Data Type: number
      Diacritics y offset attribute.
      CharacterAttributes.justificationAlternates
      Data Type: Boolean
      Justification alternates attribute.
      CharacterAttributes.overlapSwash
      Data Type: Boolean
      OpenType overlap swash attribute.
      CharacterAttributes.stretchedAlternates
      Data Type: Boolean
      Stretched alternates attribute.
      ParagraphAttributes Class
      New Properties
      ParagraphAttributes.composerEngine
      Data Type: ComposerEngineType
      Composer engine attribute.
      ParagraphAttributes.defaultTabWidth
      Data Type: number
      Default tab width attribute.
      ParagraphAttributes.kashidaWidth
      Data Type: KashidaWidthType
      The Kashida Width attribute.
      ParagraphAttributes.paragraphDirection
      Data Type: ParagraphDirectionType
      Main writing direction attribute.
      Here's the xml including all Enumerations, please note it might have missing closing tags.
      <map title="Adobe Illustrator 22 Type Library" time="Thu Feb 2 12:20:30 UTC+5 2017">
            <topicref navtitle="JPEGCompressionMethodType" href="#/JPEGCompressionMethodType" />
            <topicref navtitle="KashidasType" href="#/KashidasType" />
            <topicref navtitle="DirOverrideType" href="#/DirOverrideType" />
            <topicref navtitle="DigitSetType" href="#/DigitSetType" />
            <topicref navtitle="DiacVPosType" href="#/DiacVPosType" />
            <topicref navtitle="KashidaWidthType" href="#/KashidaWidthType" />
            <topicref navtitle="ComposerEngineType" href="#/ComposerEngineType" />
            <topicref navtitle="ParagraphDirectionType" href="#/ParagraphDirectionType" />
            <topicref navtitle="ExportForScreensScaleType" href="#/ExportForScreensScaleType" />
            <topicref navtitle="ExportForScreensType" href="#/ExportForScreensType" />
            <topicref navtitle="ExportForScreensItemToExport" href="#/ExportForScreensItemToExport" />
            <topicref navtitle="ExportForScreensOptionsJPEG" href="#/ExportForScreensOptionsJPEG" />
            <topicref navtitle="ExportForScreensOptionsPNG8" href="#/ExportForScreensOptionsPNG8" />
            <topicref navtitle="ExportForScreensOptionsPNG24" href="#/ExportForScreensOptionsPNG24" />
            <topicref navtitle="ExportForScreensOptionsWebOptimizedSVG" href="#/ExportForScreensOptionsWebOptimizedSVG" />
            <topicref navtitle="ExportForScreensPDFOptions" href="#/ExportForScreensPDFOptions" />
          <topicref navtitle="Classes used for working with (exportable) assets in Adobe Illustrator">
            <topicref navtitle="Asset" href="#/Asset" />
          </topicref>
            <topicref navtitle="Assets" href="#/Assets" />
        </map>
        <package>
          <classdef name="ExportForScreensScaleType" enumeration="true">
            <shortdesc>Export for screens scale type.</shortdesc>
            <elements type="class">
              <property name="SCALEBYFACTOR" rwaccess="readonly">
                <shortdesc>Scale artwork by factors like 1x, 2x, 3x and so on, where 1x means 72 ppi.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="SCALEBYWIDTH" rwaccess="readonly">
                <shortdesc>Scale artwork by specifying artwork width in pixels like 100px, 124px etc. Height of the artwork is adjusted automatically to maintain the aspect ratio.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="SCALEBYHEIGHT" rwaccess="readonly">
                <shortdesc>Scale artwork by specifying artwork height in pixels like 100px, 124px etc. Width of the artwork is adjusted automatically to maintain the aspect ratio.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
              <property name="SCALEBYRESOLUTION" rwaccess="readonly">
                <shortdesc>Scale artwork by specifying resolution in ppi like 72 ppi, 100 ppi, 144 ppi etc.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>3</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensType" enumeration="true">
            <shortdesc>Export for screens type.</shortdesc>
              <property name="SE_JPEG100" rwaccess="readonly">
                <shortdesc>Export file in JPEG (100% quality) format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="SE_JPEG80" rwaccess="readonly">
                <shortdesc>Export file in JPEG (80% quality) format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
              <property name="SE_JPEG50" rwaccess="readonly">
                <shortdesc>Export file in JPEG (50% quality) format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>3</value>
                </datatype>
              </property>
              <property name="SE_JPEG20" rwaccess="readonly">
                <shortdesc>Export file in JPEG (20% quality) format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>4</value>
                </datatype>
              </property>
              <property name="SE_SVG" rwaccess="readonly">
                <shortdesc>Export file in SVG format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>5</value>
                </datatype>
              </property>
              <property name="SE_PNG8" rwaccess="readonly">
                <shortdesc>Export file in PNG 8-bit format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>6</value>
                </datatype>
              </property>
              <property name="SE_PNG24" rwaccess="readonly">
                <shortdesc>Export file in PNG 24-bit format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>7</value>
                </datatype>
              </property>
              <property name="SE_PDF" rwaccess="readonly">
                <shortdesc>Export file in Acrobat PDF format.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>8</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="KashidasType" enumeration="true">
            <shortdesc>The kashida type constants.</shortdesc>
              <property name="kashidaDefault" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="kashidaOn" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="kashidaOff" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="DirOverrideType" enumeration="true">
            <shortdesc>Direction override type constants.</shortdesc>
              <property name="dirOverrideDefault" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="dirOverrideLTR" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="dirOverrideRTL" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="DigitSetType" enumeration="true">
            <shortdesc>Digit set type constants.</shortdesc>
              <property name="defaultDigits" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="arabicDigits" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="hindiDigits" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
              <property name="farsiDigits" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>3</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="DiacVPosType" enumeration="true">
            <shortdesc>Diacritic vertical position type constants.</shortdesc>
              <property name="diacVPosOff" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="diacVPosLoose" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="diacVPosMedium" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
              <property name="diacVPosTight" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>3</value>
                </datatype>
              </property>
              <property name="diacVPosOpenType" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>4</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="KashidaWidthType" enumeration="true">
            <shortdesc>The kashida width type constants.</shortdesc>
              <property name="kashidaNone" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="kashidaSmall" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="kashidaMedium" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
              <property name="kashidaLong" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>3</value>
                </datatype>
              </property>
              <property name="kashidaStylistic" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>4</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ComposerEngineType" enumeration="true">
            <shortdesc>The composer type constants.</shortdesc>
              <property name="latinCJKComposer" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="pptycaComposer" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="adornment" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ParagraphDirectionType" enumeration="true">
              <property name="leftToRight" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="rightToLeft" rwaccess="readonly">
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="JPEGCompressionMethodType" enumeration="true">
            <shortdesc>JPEG Compression Method type.</shortdesc>
              <property name="BASELINESTANDARD" rwaccess="readonly">
                <shortdesc>Select Baseline (Standard) to use a format recognized by most web browsers.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>0</value>
                </datatype>
              </property>
              <property name="BASELINEOPTIMIZED" rwaccess="readonly">
                <shortdesc>Select Baseline Optimized for optimized color and a slightly smaller file size. Not supported by all web browsers.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>1</value>
                </datatype>
              </property>
              <property name="PROGRESSIVE" rwaccess="readonly">
                <shortdesc>Select Progressive to display a series of increasingly detailed scans (you specify how many in ProgressiveScan) as the image downloads. Not supported by all web browsers.</shortdesc>
                <datatype>
                  <type>int</type>
                  <value>2</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="Assets" dynamic="true">
            <shortdesc>A collection of assets.</shortdesc>
              <method name="addFromSelection">
                <shortdesc>Creates an asset from the selected arts.</shortdesc>
                <datatype>
                  <type>Asset</type>
                </datatype>
              </method>
              <method name="add">
                <shortdesc>Creates an asset from the given art(s)</shortdesc>
                <parameters>
                  <parameter name="sourceArt">
                    <shortdesc>The page item(s) to apply to.</shortdesc>
                    <datatype>
                      <type>any</type>
                    </datatype>
                  </parameter>
                </parameters>
                <datatype>
                  <type>Asset</type>
                </datatype>
              </method>
            </elements>
            <elements type="instance">
              <property name="parent" rwaccess="readonly">
                <shortdesc>The object's container.</shortdesc>
                <datatype>
                  <type>Object</type>
                </datatype>
              </property>
              <property name="typename" rwaccess="readonly">
                <shortdesc>The class name of the object.</shortdesc>
                <datatype>
                  <type>string</type>
                </datatype>
              </property>
              <property name="length" rwaccess="readonly">
                <shortdesc>Number of elements in the collection.</shortdesc>
                <datatype>
                  <type>int</type>
                </datatype>
              </property>
              <method name="removeAll">
                <shortdesc>Deletes all elements.</shortdesc>
              </method>
              <method name="getByName">
                <shortdesc>Get the first element in the collection with the provided name.</shortdesc>
                <parameters>
                  <parameter name="name">
                    <datatype>
                      <type>string</type>
                    </datatype>
                  </parameter>
                </parameters>
                <datatype>
                  <type href="#/Asset">Asset</type>
                </datatype>
              </method>
              <method name="remove">
                <shortdesc>Deletes the asset with specified id.</shortdesc>
                <parameters>
                  <parameter name="assetID">
                    <shortdesc>UID of the asset to be deleted.</shortdesc>
                    <datatype>
                      <type href="#/Int32">Int32</type>
                    </datatype>
                  </parameter>
                </parameters>
              </method>
                <shortdesc>Gets the first asset with specified name.</shortdesc>
                <parameters>
                  <parameter name="assetName">
                    <shortdesc>Name of the asset.</shortdesc>
                    <datatype>
                      <type>string</type>
                    </datatype>
                  </parameter>
                </parameters>
                <datatype>
                </datatype>
              </method>
              <method name="getByID">
                <shortdesc>Gets the asset with the specified AssetID.</shortdesc>
                <parameters>
                    <shortdesc>The UID of the asset.</shortdesc>
                    <datatype>
                    </datatype>
                  </parameter>
                </parameters>
                <datatype>
                </datatype>
              </method>
            </elements>
          </classdef>
          <classdef name="ExportForScreensItemToExport" dynamic="true">
            <shortdesc>An item that needs to be exported; for example, a document, artboard, or asset.</shortdesc>
              <property name="artboards">
                <shortdesc>Range of artboards to export [possible values: '', 'all'(default), range]</shortdesc>
                <datatype>
                  <type>string</type>
                  <value>all</value>
                </datatype>
              </property>
              <property name="assets">
                <shortdesc>Array of asset id to export (default:empty)</shortdesc>
                <datatype>
                  <array />
                </datatype>
              </property>
              <property name="document">
                <shortdesc>Whether to export the document or not.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>false</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensOptionsJPEG" dynamic="true">
            <shortdesc>Options which may be provided when exporting a document as a JPEG100 file.</shortdesc>
              <property name="compressionMethod">
                <shortdesc>Should the image be compressed.</shortdesc>
                <datatype>
                  <type href="#/JPEGCompressionMethodType">JPEGCompressionMethodType</type>
                  <value>JPEGCompressionMethodType.BASELINESTANDARD</value>
                </datatype>
              </property>
              <property name="progressiveScan">
                <shortdesc>Specify the number of detailed scans when downloading a JPEG file using the Progressive option as the CompressionMethod.</shortdesc>
                <datatype>
                  <min>3</min>
                  <max>5</max>
                  <value>3</value>
                </datatype>
              </property>
              <property name="antiAliasing">
                <shortdesc>Should the resulting image be antialiased.</shortdesc>
                <datatype>
                  <type href="#/AntiAliasingMethod">AntiAliasingMethod</type>
                  <value>AntiAliasingMethod.ARTOPTIMIZED</value>
                </datatype>
              </property>
              <property name="embedICCProfile">
                <shortdesc>Embed an ICC profile when exporting.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="scaleType">
                <shortdesc>How should the resulting image be scaled.</shortdesc>
                <datatype>
                  <type href="#/ExportForScreensScaleType">ExportForScreensScaleType</type>
                  <value>ExportForScreensScaleType.SCALEBYFACTOR</value>
                </datatype>
              </property>
              <property name="scaleTypeValue">
                <shortdesc>The value by which the resulting image should be scaled.</shortdesc>
                <datatype>
                  <type>number</type>
                  <value>1</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensOptionsPNG8" dynamic="true">
            <shortdesc>Options which may be provided when exporting a document as an 8 bit PNG file.</shortdesc>
              <property name="colorCount">
                <shortdesc>Number of colors in exported color table.</shortdesc>
                <datatype>
                  <min>2</min>
                  <max>256</max>
                  <value>128</value>
                </datatype>
              </property>
              <property name="transparency">
                <shortdesc>Should the resulting image use transparency.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>true</value>
                </datatype>
              </property>
              <property name="interlaced">
                <shortdesc>Should the resulting image be interlaced.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="matte">
                <shortdesc>Should the artboard be matted with a color.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>true</value>
                </datatype>
              </property>
              <property name="matteColor">
                <shortdesc>The color to use when matting the artboard (default: white)</shortdesc>
                <datatype>
                  <type href="#/RGBColor">RGBColor</type>
                </datatype>
              </property>
                <datatype>
                </datatype>
              </property>
                <datatype>
                </datatype>
              </property>
                <datatype>
                  <type>number</type>
                  <value>1</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensOptionsPNG24" dynamic="true">
            <shortdesc>Options which may be provided when exporting a document as an 24 bit PNG file.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>true</value>
                </datatype>
              </property>
                <datatype>
                </datatype>
              </property>
              <property name="backgroundBlack">
                <shortdesc>Should the resulting image rasterize against a black background (with value true) or white background(with value false) if it doesn't use transparency.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
                <datatype>
                </datatype>
              </property>
                <datatype>
                  <type>number</type>
                  <value>1</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensOptionsWebOptimizedSVG" dynamic="true">
            <shortdesc>Options which may be provided when exporting a document as a web optimized SVG file.</shortdesc>
              <property name="fontType">
                <shortdesc>The type of font that should be included in the exported file.</shortdesc>
                <datatype>
                  <type href="#/SVGFontType">SVGFontType</type>
                  <value>SVGFontType.SVGFONT</value>
                </datatype>
              </property>
              <property name="coordinatePrecision">
                <shortdesc>Decimal precision for element coordinate values.</shortdesc>
                <datatype>
                  <min>1</min>
                  <max>7</max>
                  <value>3</value>
                </datatype>
              </property>
              <property name="cssProperties">
                <shortdesc>How should the CSS properties of the document be included in the document.</shortdesc>
                <datatype>
                  <type href="#/SVGCSSPropertyLocation">SVGCSSPropertyLocation</type>
                  <value>SVGCSSPropertyLocation.STYLEATTRIBUTES</value>
                </datatype>
              </property>
              <property name="svgId">
                <shortdesc>How object names (IDs) are generated in exported SVG.</shortdesc>
                <datatype>
                  <type href="#/SVGIdType">SVGIdType</type>
                  <value>SVGIdType.SVGIDREGULAR</value>
                </datatype>
              </property>
              <property name="svgMinify">
                <shortdesc>Reduces the size of the svg.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="svgResponsive">
                <shortdesc>Makes the SVG Responsive.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>true</value>
                </datatype>
              </property>
              <property name="rasterImageLocation">
                <shortdesc>Should the raster images in the exported file be included.</shortdesc>
                <datatype>
                  <type href="#/RasterImageLocation">RasterImageLocation</type>
                  <value>RasterImageLocation.PRESERVE</value>
                </datatype>
              </property>
            </elements>
          </classdef>
          <classdef name="ExportForScreensPDFOptions" dynamic="true">
            <shortdesc>Options which may be provided when exporting a document as a PDF file.</shortdesc>
              <property name="pdfPreset">
                <shortdesc>The max string length is 255 bytes. Name of PDF preset to use.</shortdesc>
                <datatype>
                  <type>string</type>
                  <value>[Smallest File Size]</value>
                </datatype>
              </property>
            </elements>
          </classdef>
              <property name="documentBleedOffset">
                <shortdesc>Document bleed offset rect.</shortdesc>
                <datatype>
                  <type href="#/Rect">Rect</type>
                </datatype>
              </property>
              <property name="documentBleedLink">
                <shortdesc>Document link for bleed values.</shortdesc>
                <datatype>
                  <type>bool</type>
                  <value>true</value>
                </datatype>
              </property>
              <method name="getIsFileOpen">
                <shortdesc>Returns if the specified filePath is open.</shortdesc>
                <parameters>
                  <parameter name="filePath">
                    <shortdesc>The filePath to be checked.</shortdesc>
                    <datatype>
                      <type>string</type>
                    </datatype>
                  </parameter>
                </parameters>
                <datatype>
                  <type>bool</type>
                </datatype>
              </method>
                  <parameter name="assetType">
                    <shortdesc>For internal use.</shortdesc>
                    <datatype>
                      <type>string</type>
                    </datatype>
                  </parameter>
              <property name="assets" rwaccess="readonly">
                <shortdesc>All assets in the document.</shortdesc>
                <datatype>
                  <type href="#/Assets">Assets</type>
                </datatype>
              </property>
              <method name="exportForScreens">
                <shortdesc>Export the specified document/asset(s)/artboard(s)</shortdesc>
                <parameters>
                  <parameter name="exportFolder">
                    <shortdesc>The folder where the exported documents/assets/artboards are saved.</shortdesc>
                    <datatype>
                      <type href="#/File">File</type>
                    </datatype>
                  </parameter>
                  <parameter name="exportFormat">
                    <shortdesc>The file type in which the document is exported.</shortdesc>
                    <datatype>
                      <type href="#/ExportForScreensType">ExportForScreensType</type>
                    </datatype>
                  </parameter>
                  <parameter name="options" optional="true">
                    <shortdesc>Options for the file type specified.</shortdesc>
                    <datatype>
                      <type>any</type>
                    </datatype>
                  </parameter>
                  <parameter name="itemToExport" optional="true">
                    <shortdesc>What to export.</shortdesc>
                    <datatype>
                      <type href="#/ExportForScreensItemToExport">ExportForScreensItemToExport</type>
                    </datatype>
                  </parameter>
                  <parameter name="fileNamePrefix" optional="true">
                    <shortdesc>String prepended to each file name.</shortdesc>
                    <datatype>
                      <type>string</type>
                    </datatype>
                  </parameter>
                </parameters>
              </method>
              <property name="start">
                <shortdesc>Start index of the text range.</shortdesc>
                <datatype>
                </datatype>
              </property>
              <property name="end">
                <shortdesc>End index of the text range.</shortdesc>
                <datatype>
                </datatype>
              </property>
              <method name="getTextRunLength">
                <shortdesc>Get the length of the first text run.</shortdesc>
                <datatype>
                </datatype>
              </method>
              <method name="getParagraphLength">
                <shortdesc>Get the length of the first paragraph.</shortdesc>
                <datatype>
                </datatype>
              </method>
              <property name="kana">
                <shortdesc>Does the Japanese OpenType support kana?</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="ruby">
                <shortdesc>Does the Japanese OpenType support ruby?</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="kashidas">
                <shortdesc>Kashidas attribute.</shortdesc>
                <datatype>
                  <type href="#/KashidasType">KashidasType</type>
                </datatype>
              </property>
              <property name="dirOverride">
                <shortdesc>Direction override attribute.</shortdesc>
                <datatype>
                  <type href="#/DirOverrideType">DirOverrideType</type>
                </datatype>
              </property>
              <property name="digitSet">
                <shortdesc>Digit set attribute.</shortdesc>
                <datatype>
                  <type href="#/DigitSetType">DigitSetType</type>
                </datatype>
              </property>
              <property name="diacVPos">
                <shortdesc>Diacritics positioning attribute.</shortdesc>
                <datatype>
                  <type href="#/DiacVPosType">DiacVPosType</type>
                </datatype>
              </property>
              <property name="diacXOffset">
                <shortdesc>Diacritics x offset attribute.</shortdesc>
                <datatype>
                  <type>number</type>
                </datatype>
              </property>
              <property name="diacYOffset">
                <shortdesc>Diacritics y offset attribute.</shortdesc>
                <datatype>
                  <type>number</type>
                </datatype>
              </property>
              <property name="overlapSwash">
                <shortdesc>OpenType overlap swash attribute.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="justificationAlternates">
                <shortdesc>Justification alternates attribute.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="stretchedAlternates">
                <shortdesc>Stretched alternates attribute.</shortdesc>
                <datatype>
                  <type>bool</type>
                </datatype>
              </property>
              <property name="defaultTabWidth">
                <shortdesc>Default tab width attribute.</shortdesc>
                <datatype>
                  <type>number</type>
                </datatype>
              </property>
              <property name="paragraphDirection">
                <shortdesc>Main writing direction attribute.</shortdesc>
                <datatype>
                  <type href="#/ParagraphDirectionType">ParagraphDirectionType</type>
                </datatype>
              </property>
              <property name="kashidaWidth">
                <shortdesc>The Kashida Width attribute.</shortdesc>
                <datatype>
                  <type href="#/KashidaWidthType">KashidaWidthType</type>
                </datatype>
              </property>
              <property name="composerEngine">
                <shortdesc>Composer engine attribute.</shortdesc>
                <datatype>
                  <type href="#/ComposerEngineType">ComposerEngineType</type>
                </datatype>
              </property>
                </datatype>
              </method>
            </elements>
          </classdef>
          <classdef name="Asset" dynamic="true">
            <shortdesc>An (exportable) asset.</shortdesc>
                <datatype>
                  <type>Object</type>
                </datatype>
              </property>
                <datatype>
                  <type>string</type>
                </datatype>
              </property>
              <property name="assetID" rwaccess="readonly">
                <shortdesc>The UID for the asset which is unique within a document.</shortdesc>
                <datatype>
                </datatype>
              </property>
              <property name="assetName">
                <datatype>
                  <type>string</type>
                </datatype>
              </property>
                <shortdesc>Deletes this object.</shortdesc>
              </method>
              </method>
              <method name="getNormalizedName">
                <shortdesc>Gets the normalized name without special characters, such that it can be used as a file name.</shortdesc>
                <datatype>
                  <type>string</type>
                </datatype>
              </method>
            </elements>
          </classdef>
        </package>
