I´ve been searching a lot to find info about if the Recolor Artwork pane is scriptable but did not found any. So my question is if anybody know if it´s possible to control it via Javascript?
Hi
I wrote a script to do this which I sell, but I had written my own ICC full color engine and color tools in JS, and I also wrote a decoder to read the .acb files directly to get their lab vales etc.
If you want to do this yourself in JavaScript you need to
Hi, no, Recolor Panel is not accessible. We must use other methods to recolor objects.
Hi
What particular features are you looking to use for recoloring?
Glenn
O2 Creative
I want to convert CMYK and RGB to spotcolors (Pantone Solid Coated) I know that the user Qwertyfly have modified a script to do this, however Im finding the results in the recoloring pane to be better so that´s why.
Hi
Hope that helps.
Glenn
O2 Creative
Yeah, exactly what im gonna do. Never thought i could add all swatches to a doc. I simply run a loop store them and save them to a file. Now i can update that Wundes script which can search for PMS colors. I would need to get official PMS CP colors to get the proper match i guess
EDIT
Ive now also got it working so i can convert colors to PMS using internal code. I do see a difference though from when using the recolor method. It has slightly different results. Some look better, some are a bit off. Still need to work a bit on this i guess
