• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Illustrator 2018 error loding Autocad DWG
Participant ,
Oct 23, 2017 Oct 23, 2017
I used to load Autocad DWG files sent by my clients to do conversions and export hi res images from them, last night I've updated to illustrator 2018 and now I can't load DWGs anymore, there is an error saying that is an unknown format...
Views
12.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 18, 2018 Jun 18, 2018
2013 will not work.
2010 is the highest version Illustrator can handle.
Votes
Translate
Translate
Adobe
Adobe Employee ,
Hi juvelez,
Would you mind sharing a sample file on which you are getting this error?
Regards
Srishti
Votes
Translate
Translate
Report
Report
Participant ,
I'm getting this error with every AutoCAD file that loaded fine with the previous version, I work all days with those files, yesterday I was able to load them, today, after the update to 2018, I can't load them anymore.
You can try with this simple file: Dropbox - AutoCAD Import Testing File.dwg ​
If you're able to load this file, so the problem is with my installation...
Votes
Translate
Translate
Report
Report
Guide ,
I cannot load it either
But hard to tell, because that test file looks like it's saved as Autocad 2013 .dwg, and Illustrator, as far as i know, cannot open versions later than, at most  2010.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 26, 2017 Oct 26, 2017
Hi juvelez,
Could you please confirm in which version these files were created?
Regards
Srishti
Votes
Translate
Translate
Report
Report
New Here ,
Dec 13, 2017 Dec 13, 2017
was this issue ever solved?
Votes
Translate
Translate
Report
Report
Community Expert ,
Which issue?
We don't even know the version of the DWG mentioned in this thread.
If you have issues with an AutoCAD up to 2010, then upload the file somewhere for people  to test.
If you have issues with a higher version, then save it to version 2010 and try again.
Votes
Translate
Translate
Report
Report
New Here ,
I'm not sure what my file is.  A customer sent us a DWG file, I'm trying to open in AI CC 2018.  I get the same error as she did...
Votes
Translate
Translate
Report
Report
Community Expert ,
You will need to ask for the version.
Or maybe just ask for a version 2010 file.
Votes
Translate
Translate
Report
Report
New Here ,
Yup! they were able to send it as a pdf
Votes
Translate
Translate
Report
Report
Guide ,
Votes
Translate
Translate
Report
Report
New Here ,
Dec 12, 2017 Dec 12, 2017
I am getting the same error message.  Oddly, .dwg is a valid extension in the "file types" menu. Is this a 2018 update bug??
Votes
Translate
Translate
Report
Report
New Here ,
Jan 15, 2018 Jan 15, 2018
I am trying to open an Autocad 2004 version file but I just open a blank page. Placing doesn't work either. Anyone know if CC 2018 is able to work with .dwg files at all? I need this capability and its why I use Illustrator.
Thanks, Susan
Votes
Translate
Translate
Report
Report
Community Expert ,
That version should work.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 19, 2018 Feb 19, 2018
You could also ask your clients to save the file as a .dxf from CAD. Then you should be able to open in Illustrator.
Votes
Translate
Translate
Report
Report
New Here ,
Having the same issue here opening dwg files. My client sent a 2013 version and I still got the same error. I was able to open these files before. Any solution?
Votes
Translate
Translate
Report
Report
Community Expert ,
2013 will not work.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 19, 2018 Jun 19, 2018
Thank you. They finally stepped it back to the 2007 version and it worked.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
If you're only using it to generate a high res image I would ask your clients to send you a PDF of the file. You then have a variety of options for exporting them as high res images. From Acrobat, or placing them in PS or AI.
Votes
Translate
Translate
Report
Report
