• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
3d Camera Track Error CC 18
Explorer ,
Oct 24, 2017 Oct 24, 2017
I cannot get this shot to track..I keep getting not able to solve camera error.
https://www.dropbox.com/s/gxdews8yuzxhdbi/001.mp4?dl=0
This is the clip that I cannot get to track..seems pretty basic to me?
Any thoughts?
Views
246
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 24, 2017 Oct 24, 2017
I don’t have time to try it but I’d duplicate your footage layer, mask out the actor, pre-compose the top copy and camera track the pre-comp with no actor in the shot. The hole should not foul up the tracking, the actor probably is. If you get a good camera track, then set an origin and ground plane, add your reference solids, then turn off the pre-comp and move on. If you can’t get a good track try adding some color correction or other effects to the original footage in the pre-comp to give you
Votes
Translate
Translate
Community Expert ,
I don’t have time to try it but I’d duplicate your footage layer, mask out the actor, pre-compose the top copy and camera track the pre-comp with no actor in the shot. The hole should not foul up the tracking, the actor probably is. If you get a good camera track, then set an origin and ground plane, add your reference solids, then turn off the pre-comp and move on. If you can’t get a good track try adding some color correction or other effects to the original footage in the pre-comp to give you some more detain in the shot.
If that does not work let us know. I may take a look at your shot later this morning.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
That did the trick thanks a bunch!!!!
Votes
Translate
Translate
Report
Report
