I have just updated to Photoshop 2018 on my Windows 7 64 bit machine with 16 GB of RAM. I found that when using Camera as Filter it crashes Photoshop. Launching Camera Raw from the filter menu is fine ACR opens and allow edit/changes to be made however after clicking the OK button I'm brought back to Photoshop and Photoshop no longer responds instead I have to launch the Windows Task Manager and "end the task." Does anyone kjnow a fix for this?
Third-party GPU overclocking utilities and haxies are not supported (examples include Riva Tuner and MSI Afterburner).
Bahaar, thanks for getting back to me so quickly. I wanted to clarify a few things that I probably should have initially mentioned. My GPU is not overclocked, Item number 1 of your reply would not apply as I am running Windows 7 64 bit and item number 3, Graphics Processor option for Camera Raw was not selected. Related to item 2 rather run out and purchase a new adapter as suggested I have tried downloading the latest video driver for my adapter before spending additional money on a new adapter however the issue still persist.
Attention Bahaar Kham Oct 24, 2017. Regarding latest update for PS CC 2018 with ACR. ACR was crashing PS CC 2018 when opening Canon CR2 RAW files via PS Open, double-clicking image icon and opening via new Bridge 2018. I tried all recommendations that I found at Adobe Forums and others on internet regarding the new version of PS CC 2018 crashing. Then I found your your instructions here in reply to Howard53's problem with ACR crashing PS 2018 when ACR was used as a filter. You suggested to Deselect Use Graphics Processor in the Camera Raw setting. Wow; I uninstalled, re-installed, changed settings, reset PS Preferences, checked for updates to video driver, etc. and nothing worked until I Deselected Use Graphics Processor in the Camera Raw preferences. Such a little thing that use to be deselected but down loading the newest PS CC 2018 version must have set this item to the Selected position. Thanks again Bahaar Kham. I have printed your suggestions posted here to save for next time I can not figure this problem out by my self. Your humble servant; Gary
Any thoughts on if trying to even ACCESS the Camera Raw setting crashes PS too? I click on Edit>Camera Raw and PS immediately crashes. This happens now on PSCC 2018 as well as the previous versions I tried to install. Camera Raw can't be rolled back so I'm unable to go to previous version of it.
I'm in the same boat with Camera Raw crashing when trying to open the Preferences in Photoshop. Can't open raw files or Jpgs due to this. Every other file format is fine in Photoshoip. Camera Raw doesn't show as an option to "open in" in bridge either. I'm also on a Windows 7 64-bit machine with CC 2018 and the latest Camera Raw installed. Everything hit the fan today after the updates
The AMD Driver update did the trick for me!
Happy to help you Gary! Glad your issue is solved.
Go into Camera Raw Preferences from Bridge and uncheck "use graphics processor"
Installed Bridge just to do this; found that the default was unchecked already, so I'm still in the same boat. 😞
I've tried that various times. Doesn't fix the issue on my end.
