2 Replies Latest reply on Oct 24, 2017 10:18 AM by Fjuds
    Stripping first 4 characters in a 8 character file name inside a script?
    Fjuds
      I have a script to add the file number to the front of the image for proofing. I would like to remove the first 4 characters in the 8 character file name in the script.
      I don't code so I'm looking for the lines of code to add to the script.
      It would help reduce paperwork errors when we show portraits.
      Thanks for any help,
      Fjuds
      // this script is a variation of the script addTimeStamp.js that is installed with PH7
      if ( documents.length > 0 )
        var originalRulerUnits = preferences.rulerUnits;
        preferences.rulerUnits = Units.PIXELS;
        try
        var docRef = activeDocument;
        // Now create a text layer at the front
        var myLayerRef = docRef.artLayers.add();
        myLayerRef.kind = LayerKind.TEXT;
        myLayerRef.name = "Filename";
        var myTextRef = myLayerRef.textItem;
        // strip the extension off
        var fileNameNoExtension = docRef.name;
        fileNameNoExtension = fileNameNoExtension.split( "." );
        if ( fileNameNoExtension.length > 1 ) {
        fileNameNoExtension.length--;
        fileNameNoExtension = fileNameNoExtension.join(".");
        myTextRef.contents = fileNameNoExtension;
        // off set the text to be in the bottom center
        myTextRef.position = new Array( docRef.width / 3, docRef.height / 1.03 );
        myTextRef.size = 60;
        catch( e )
        // An error occurred. Restore ruler units, then propagate the error back
        // to the user
        preferences.rulerUnits = originalRulerUnits;
        throw e;
        // Everything went Ok. Restore ruler units
      else
        alert( "You must have a document open to add the filename!" );
        • 1. Re: Stripping first 4 characters in a 8 character file name inside a script?
          SuperMerlin Level 5
            try
            myTextRef.contents = decodeURI(docRef.name).replace(/\.[^\.]+$/, '').match(/(....)(.+)/)[2];
            }catch( e ){
            // to the user
            throw e;
          else
          • 2. Re: Stripping first 4 characters in a 8 character file name inside a script?
            Fjuds Level 1
            Hello Super Merlin,
            Thanks it works great. It should solve a periodic problem I have with mis marked orders. It definitely simplifies the file name on the proof.
            I had made miner mods to the script but adding code is out of my wheel house.
            Thanks Again,
            Frank
