After watching a tutorial on the refine brush tool for masking, it was advised to use photoshop 2015 since you can have parallel installs. I am working on a PC with Windows 10. Since installing 2015 I cannot set Photoshop 2017 as a default for anything, it is not even an oprtion. I can only select from the windows app store. I am guessing this s a registry fix so I am hoping someone can direct me to that edit.
Thanks!
RL
I no longer have many versions of Photoshop Installed for window 10 Preview build Green screened and I had to install Windows 10 to get my machine working. So all my application needed to be installed. So I decided to only install the version of Photoshop that I had installed that I felt were useful to have. I did not install CS2, CS3, CC, CC 2015, CC 2015.5 and CC 2017. I installed CS6, CC 2014 and CC 2018 to test. I use CC 2014. However, installing CC 2018 changed many file type association to CC 2018, and made CC 2018 the default Photoshop application. I use Regedit to change Windows Photoshop.exe key shell commands Edit and open from CC 2018 back to CC 2014. I also change some File Type extension from CC 2018 to CC 2014. Either using Windows 10 settings or from windows explorer "open with" and "chose other application" where I checked the Always check box.
Hi RL,
Please rename the app "Photoshop.exe" to "PhotoshopCC2018.exe" and let us know if that helps.
Akash
