17 Replies Latest reply on May 21, 2008 9:57 AM by MergeThis
    Heading Styles
    harooki2 Level 1
      WebHelp Pro
      RH7
      I am re-working a style sheet nightmare, like so many of us. To do so, I am selecting all in each topic and applying Normal to all the text. I have then applied Heading 1 to the topic title, and all I've done to that is raise the font size to 25pt in the style sheet. No matter what I do, though, the correct Heading 1 style does not show up when I compile and preview.
      I don't know what style it is, but it isn't Heading 1. I have even deleted the old topic title, retyped it, and applied Heading 1. What am I doing wrong?
        • 1. Re: Heading Styles
          kmaddox1 Level 1
          you might try applying "(none)" instead of Normal to your headings before you re-style.... I think that (none) does a better job of stripping out any underlying codes
          • 2. Re: Heading Styles
            kmaddox1 Level 1
            • 3. Re: Heading Styles
              kmaddox1 Level 1
              • 4. Re: Heading Styles
                kmaddox1 Level 1
                oops, sorry for the triplicate reply, my computer's very slow to respond today...
                • 5. Heading Styles
                  harooki2 Level 1
                  Thanks, but that didn't work. The only way I can get Heading1 to work is to create a new topic.
                  I've searched the style sheet and the styles available in this topic, and there's no style that even looks like what is being rendered. And, by the way, what are styles that are named "whs" followed by a number?
                  I have found that creating a new topic, then cut & pasting from the old topic resolves this problem. However, it will probably create others; and I want to know what's going on here. Although I have the workaround, I still would appreciate expert feedback.
                  • 6. Re: Heading Styles
                    Have you looked at the HTML code in True Code / HTML View/
                    • 7. Re: Heading Styles
                      MergeThis Level 4
                      The "whs" styles appear only in the output files, indicating that RH has converted your source styles into browser-friendly styles.
                      As Peter suggests, try checking the TrueCode for one of the topics. You could even copy one of the H1 elements (the entire line[s]) and provide it here using the Attach Code button below. We might spot the problem easier if we can see that.
                      Leon
                      • 8. Re: Heading Styles
                        harooki2 Level 1
                        This is the second time someone has mention the Attach Code button. Can someone tell me specifically where that button is? I can't find it.
                        • 9. Re: Heading Styles
                          RoboColum(n) Level 5
                          It does not appear if you use the "Quick Reply" button to post to these forums. Instead click on the "Reply" link above each post and you'll find it there.
                          • 10. Re: Heading Styles
                            harooki2 Level 1
                            The code for each of these headings (the bad one and good one) are exactly the same. Unless I misunderstand what I should be looking for, the text is enclosed with a simple h1 tag.
                            • 11. Re: Heading Styles
                              Can I step back a bit. Have you got the correct style sheet assigned to the topics? Remember that templates also have a style sheet assigned to them.
                              • 12. Re: Heading Styles
                                harooki2 Level 1
                                Wow, I thought you had it. That sounded so good, because there was a template attached to the bad one. So, I removed it.
                                Both topics have the same style sheet attached. They both now have no template attached. But, alas, I'm getting the same result.
                                • 13. Re: Heading Styles
                                  If you are using folders inside your project, check that there isn't another version of the style sheet inside the folder where the offending topic exists. You can check this quickly by using the Topic Properties report with the Style Sheet option selected.
                                  • 14. Heading Styles
                                    harooki2 Level 1
                                    I have done that, but I created the style sheet as a precaution against something like that fouling things up.
                                    Hold on, this may be the problem. I see a difference in the paths to the style sheet.
                                    The style sheet shown in the report for the bad one is:
                                    C:\Documents and Settings\RALEE\Desktop\Price Management.css
                                    The style sheet shown in the report for the good one is:
                                    C:\Documents and Settings\RALEE\Desktop\P2P Price Management Procedures\Price Management.css
                                    This, in itself, puzzles me. I don't know why the paths differ, because I created this css while in my project (which is in C:\Documents and Settings\RALEE\Desktop\P2P Price Management Procedures. So, now I'm really confused.
                                    • 15. Re: Heading Styles
                                      Hi Harooki
                                      When you are editing your forum post via the web interface, look below where you type your reply. I'll upload a screen capture for you.
                                      Click here to see
                                      Cheers... Rick
                                      • 16. Re: Heading Styles
                                        Hi all
                                        Apologies if someone else has offered this and I overlooked it.
                                        Harooki, if you examine the HTML code of your topic and look near the top, you should see a Head section. Inside that section may be lurking an embedded style. It might look like this:
                                        <style type="text/css"><!--
                                        H1 {
                                        font-size: 24pt;
                                        color: #800000;
                                        LI.H1 {
                                        font-size: 24pt;
                                        color: #800000;
                                        </style>
                                        Note that I just tossed one together to see what it might look like. Your code (I'm guessing this is the issue) would look different, yet still start and end with <style> and </style>.
                                        See if you can find that and blow it away. Always remember that embedded styles will override style sheets.
                                        Again, apologies if this has already been covered. I did scan the longish thread but don't recall seeing it.
                                        Cheers... Rick
                                        • 17. Re: Heading Styles
                                          MergeThis Level 4
                                          You might also move your project closer to the C: drive by eliminating what I've changed to bold:
                                          C:\ Documents and Settings\RALEE\Desktop\P2P Price Management Procedures\Price Management.css
                                          Having RH projects on the Desktop is not best practice.
                                          Leon
