0 Replies Latest reply on Jun 20, 2008 1:44 PM by realtime158
    Passing variables
    realtime158
      So I have the following class below flxScript. Which basically is used to show another mxml component in the view stack. Basically you will see this line in the code
      this.userID=evt.result.user;
      then you will see getusrID(); When the user logs in the view stack changes to another mxml component. How do I pass the value from getuserID to label field in the mxml component called dashboard.
      Here is what the class looks like below and thanks for everybody that helps.
