5 Replies Latest reply on May 20, 2008 9:32 PM by kglad
    Importing 2 .as files
    trigger2160 Level 1
      I am having a problem importing two .as files. i have my .fla file in a directory plus two .as files, one is called classA.as and the other is called classB.as. if i import either of these classes into the .fla file then everything is fine. if i import both classes on the same frame then i get the error message below:
      "**Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 4: The class 'ClassB.as' cannot be imported because its leaf name is already being resolved to imported class 'ClassA.as'.
      import ClassB.as;"
      the code that i use to import both classes is the following:
      import ClassA.as;
      import ClassB.as;
      before i restructured my code i had the part to do with ClassA on one frame and the part to do with ClassB on another frame and this worked fine. so why can i not have all my code on one frame and import both classes at once?
