• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
3D Export Does Not Recognize Opacity at 0%
Contributor ,
Oct 25, 2017 Oct 25, 2017
I watched this tutorial, and halfway through he teaches you to cut a hole in the object, reducing drawn Opacity to 0%.
I want to export the model with the hole in my mesh, very similar to the object he created, but when opening the file after exporting, the hole is not there.
I just want to do whatever it takes to make my objects hollow, so textures can be drawn inside and out.
Even doing that without punching a hole would be cool, too.
Photoshop for 3D Printing _ Class Two_Create, color and create a hollow object - YouTube
Views
393
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
He did not create a hole in the mesh - he just created an opacity map to make the texture clear at that point.
Try exporting as Collada (.dae) and ensure you have included the textures - one of which will be opacity
Dave
Votes
Translate
Translate
Report
Report
Contributor ,
When I exported it, I just clicked Export and usually all textures go with it.  If I need to do that manually, how would I?
Votes
Translate
Translate
Report
Report
Community Expert ,
When you click 3D export you get a choice of formats - which did you use
Dave
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi
I think I have found a problem - but it would be good if you could confirm you are seeing the same.
If I export to obj format - the file is saved along with the opacity map
However - if I import to CC2018 then that opacity map is ignored. Importing the same object to CC2017 results in the opacity material being applied correctly.
So the problem I am seeing is on Import not Export
Dave
Votes
Translate
Translate
Report
Report
Contributor ,
.dae
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi
I could not replicate that .
I exported as Collada (.dae) and got the files below
Opening them in a new document showed the opacity correctly
Dave
Votes
Translate
Translate
Report
Report
Contributor ,
Oct 26, 2017 Oct 26, 2017
LATEST
Hmm.  I'm opening it in a 3rd party program...
That may be the problem.
Votes
Translate
Translate
Report
Report
Contributor ,
Include Textures IS clicked when exporting everything I export, by the way
Votes
Translate
Translate
Report
Report
