Hi... I found this great tutorial for "Matrix" cascading code in Flash, but the code has errors. The full tutorial and code is at Flash Matrix - Animated Code Effect ...
Here's the part of the code w/ the problem (lines 75 - 88):
if(this.ind < this.myCodes.length and this.delay != 0){
this.ind++;
this.delay--;
} else {
this.ind = 0;
this.delay = this.myCodes.length;
When I test it I get error:
Scene 1, Layer 'Layer 1', Frame 1, Line 75, Column 35 1084: Syntax error: expecting rightparen before and.
When I placed the rightparen before and, I get error:
Symbol 'one_pod', Layer 'Actions', Frame 1, Line 80, Column 3 1083: Syntax error: else is unexpected.
... and haven't found a fix for the else... I'm not a good actionscripter so kind of hit a wall here... Any ideas?
Thanks!
(I emailed the author re/ this but he hasn't responded...)
"and" in your if-statement should be "&&"
