1 Reply Latest reply on Oct 27, 2017 7:14 AM by robdillon
    ActionScript 3 syntax error 1083
    TPH15 Level 1
      Thanks  in advance for your help!
      Someone very kindly helped me out on creating a youtube player for flash with ActionScript 3, however when I test the movie it comes up with error 1083, unexpected rightbrace, which happens to be the last right brace at the end of the program. If I take away that right brace, I then receive both errors 1083 and 1084 (end of program is unexpected and expecting rightbrace before end of program. Here's the code itself:
      import flash.system.Security;
      Security.allowDomain( '*' );
      Security.allowInsecureDomain( '*' );
      var vPlayer:Object;
      var playerLoader:Loader;
      function loadVideo():void
        playerLoader
      = new Loader();
      // next line loads a youtube player with no UI
        playerLoader
      .load( new URLRequest( 'http://www.youtube.com/apiplayer?version=3' ) );
      // wait for it to load
        playerLoader
      .contentLoaderInfo.addEventListener( Event.INIT, onLoaderInit );
      function onLoaderInit( evt:Event ):void
      // 'vPlayer_container' is a movieclip on stage same size as video player you need.
      // add your youtube Loader, ( which is actually the player ), to vPlayer_container's display list.
        vPlayer_container
      .addChild(playerLoader);
      // set the vPlayer variable to be the loaded youtube player
        vPlayer
      = playerLoader.content;
      // wait for it to be ready
        vPlayer
      .addEventListener( 'onReady', onPlayerReady );
      function onPlayerReady( evt:Event ):void
        vPlayer
      .removeEventListener( 'onReady', onPlayerReady );
      // set listener for onComplete and play/pause events
        vPlayer
      .addEventListener( 'onStateChange', onPlayerStateChange );
      // mute it on start if you want
        vPlayer
      .mute();
      // set size of video screen
        vPlayer
      .setSize( 392,220 );
      // now load your youtube video in your new youtube player
      // get this video number off the url to your youtube video
        vPlayer
      .loadVideoById( 'GEghz32qhiA', 0 );
      function onPlayerStateChange( evt:Event ):void
      // if video is over
      if( Object(evt).data == 0 ) //do something when video is over
