2 Replies Latest reply on Oct 27, 2017 9:58 PM by systems01h61704443
    Japanese Text is not shown Correctly in UI For CC 2017
    systems01h61704443 Level 1
      Dear Friends,
        I create a plugin For Illustrator CC 2017.
        I created the UI Using HTML5 and JSP.
        I used japanese Text in the  The Label Controls.
        The Japanese Texts Are not Shown Correctly in the UI.This is the Problem.
        I try the Japanese Text in FreeGridUI.The Same Problem occurs.
        please see the Below Image
      please see the code below
      index.html:
      <?xml version="1.0"?>
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html
        xmlns="http://www.w3.org/1999/xhtml">
        <head>
        <script src="../js/jquery-1.9.1.min.js"></script>
          <script src="../js/CSInterface.js"></script>
          <script src="../js/main.js"></script>
        <link rel="stylesheet" type="text/css" href="../css/freegrid.css">
        </head>
        <body>
        <form role="form" id="settingsForm">
        <div class="row">
        <div class="col">
          <label><input type="radio" name="translateRadio" id="translateRadio" value="translate"> 翻訳</label>
        </div>
        <div class="col">
        <div class="row">
        <div class="col">
        <label for="offsetX">OffsetX</label>
          <input type="number" id="offsetX" placeholder="0" min="0" disabled="true">
        </div>
        </div>
        <div class="row">
        <div class="col">
        <label for="offsetX">OffsetY</label>
        <input type="number" id="offsetY" placeholder="0" min="0" disabled="true">
        </div>
        </div>
        </div>
        </div>
        <div class="row">
        <div class="col">
          <label><input type="radio" name="scaleRadio" id="scaleRadio" value="scale"> Scale %</label>
        </div>
        <div class="col">
        <input type="number" id="scale" placeholder="100" min="0" disabled="true">
        </div>
        </div>
        <div class="row">
        <div class="col">
          <label><input type="radio" name="rotateRadio" id="rotateRadio" value="rotate"> 回転する</label>
        </div>
        <div class="col">
        <input type="number" id="rotate" placeholder="0" min="0" max="360" disabled="true">
        </div>
        </div>
        <div class="row">
        <div class="col">
          <label><input type="radio" name="moveToRadio" id="moveToRadio" value="moveTo"> MoveTo</label>
        </div>
        <div class="col">
        <select id="move" name="move" disabled>
        <option>RightPlane</option>
          <option>LeftPlane</option>
        <option>FloorPlane</option>
        </select>
        </div>
        </div>
        <div class="row">
        <div class="col">
          <button type="submit" class="btn btn-default" onclick="addCombo()">Transform</button>
        </div>
        </div>
        </form>
        </body>
      </html>
      I try to edit <LocaleList> in manifest.xml.But The Problem is not Solved.
      manifest.xml
      <ExtensionManifest
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ExtensionBundleId="com.mycompany.freegridui" ExtensionBundleVersion="1.0.0" Version="5.0">
        <ExtensionList>
          <Extension Id="com.adobe.illustrator.freegridui.panel" Version="1.0.0"/>
        </ExtensionList>
        <ExecutionEnvironment>
          <HostList>
            <Host Name="ILST" Version="20.0"/>
          </HostList>
          <LocaleList>
            <Locale Code="en_ME" />
        <Locale Code="pt_BR" />
        <Locale Code="en_US" />
        <Locale Code="pl_PL" />
        <Locale Code="ja_JP" />
        <Locale Code="ru_RU" />
        <Locale Code="zh_CN" />
        <Locale Code="uk_UA" />
        <Locale Code="ro_RO" />
        <Locale Code="el_GR" />
        <Locale Code="pt_PT" />
        <Locale Code="en_GB" />
        <Locale Code="en_IE" />
        <Locale Code="cs_CZ" />
        <Locale Code="zh_TW" />
        <Locale Code="he_IL" />
        <Locale Code="nb_NO" />
        <Locale Code="fr_CA" />
        <Locale Code="es_ES" />
        <Locale Code="ko_KR" />
        <Locale Code="fi_FI" />
        <Locale Code="de_DE" />
        <Locale Code="it_IT" />
        <Locale Code="en_CE" />
        <Locale Code="hu_HU" />
        <Locale Code="fr_FR" />
        <Locale Code="es_MX" />
        <Locale Code="ar_AE" />
        <Locale Code="tr_TR" />
        <Locale Code="sv_SE" />
        <Locale Code="da_DK" />
        <Locale Code="nl_NL" />
          </LocaleList>
          <RequiredRuntimeList>
            <RequiredRuntime Name="CSXS" Version="5.0"/>
          </RequiredRuntimeList>
        </ExecutionEnvironment>
        <DispatchInfoList>
          <Extension Id="com.adobe.illustrator.freegridui.panel">
            <DispatchInfo>
              <Resources>
                <MainPath>./html/index.html</MainPath>
                <CEFCommandLine/>
              </Resources>
              <Lifecycle>
                <AutoVisible>true</AutoVisible>
              </Lifecycle>
              <UI>
                <Type>Panel</Type>
                <Menu/> <!-- menu is provided by illustrator plug-in -->
                <Geometry>
                  <Size>
        <Height>226</Height>
        <Width>350</Width>
                  </Size>
                  <MinSize>
        <Width>350</Width>
                  </MinSize>
                  <MaxSize>
        <Width>350</Width>
                  </MaxSize>
                </Geometry>
                <Icons/>
              </UI>
            </DispatchInfo>
          </Extension>
        </DispatchInfoList>
      </ExtensionManifest>
      Please give Your Suggestion to solve this Problem
      Thank You Friends,
      Vicky
