1. Re: Windows 10 start menu icons messed up for all apps after update
kglad Oct 27, 2017 7:09 AM (in response to wdburgdorf)google: win 10 repair icons
2. Re: Windows 10 start menu icons messed up for all apps after update
wdburgdorf Oct 27, 2017 8:14 AM (in response to kglad)That was of course the first thing I tried. Applied some "fixes", at least the broken icons that I had added myself disappeared. But there is no general issue with the icons. Just with Adobe icons, after yesterdays updates. Meanwhile I found that on my admin account the icons are ok. Just on my work account they are broken. Before the updates everything was fine.
3. Re: Windows 10 start menu icons messed up for all apps after update
kglad Oct 27, 2017 8:16 AM (in response to wdburgdorf)1 person found this helpfuli think that's still your best bet.
this is the only non-forum info on adobe.com that i could find, Application icons change to Acrobat or Reader icon on Windows
4. Re: Windows 10 start menu icons messed up for all apps after update
wdburgdorf Oct 27, 2017 9:00 AM (in response to kglad)Ok, if I'm the only one who has this issue, I will have to try more of those Windows fixes.
The suggestions in your link are for older versions of Windows. I have tried some of those things, especially icon db refresh with the Win10 version of it. But it is definitely not only an icon issue, it's the links that I don't get to work anymore.
Anyway, thanks for your replies and suggestions.
5. Re: Windows 10 start menu icons messed up for all apps after update
fenjas29325284 Oct 27, 2017 9:19 AM (in response to wdburgdorf)1 person found this helpfulTry this path to the start menu:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Not sure if it works for you - I'm the only user and admin of the machine.
Fenja
6. Re: Windows 10 start menu icons messed up for all apps after update
kglad Oct 27, 2017 12:20 PM (in response to wdburgdorf)if it's not an icon problem but a path problem, recreate your shortcuts.
7. Re: Windows 10 start menu icons messed up for all apps after update
wdburgdorf Nov 6, 2017 7:18 AM (in response to wdburgdorf)1 person found this helpfulMeanwhile, after yet another restart, it seems fixed. Still I need to manually recreate all icons. And (of course?) the application defaults are also broken. But that is an issue I had for years. Especially Photoshop - it never appears in the suggested application list for images ... But that's a different issue.
Thank you all for your replies.
8. Re: Windows 10 start menu icons messed up for all apps after update
kglad Nov 6, 2017 7:21 AM (in response to wdburgdorf)you're welcome. (and glad that's sorted, hopefully never to recur.)
9. Re: Windows 10 start menu icons messed up for all apps after update
Lost Hiker Feb 3, 2018 4:03 PM (in response to wdburgdorf)This just happened to me. The icons either turned "white" and when I clicked on "Properties" it said there was some kind of problem. So, I ended up deleting the shortcut icons on the desktop for Photoshop, Lightroom and Bridge. Then I did a search using the Cortana "Type here to search" box on the task bar and typed in the name of the app icon. When the name came up, I right clicked and then clicked on "open file location." Then I clicked on the file name and clicked again on "send to". Clicked again on "Desktop". Icons are all back and everything works. I had one other unrelated icon that was suffering a similar "white" problem, so I deleted it and went through the same process, and now everything is okay again.
