3 Replies Latest reply on Nov 3, 2017 4:55 AM by danp44833468
    Modify an old PDF from 1999 - PDF Version 1.2(Acrobat 3.x)
    danp44833468 Level 1
      I have a pdf from 1999 that I need to update the logo in.  I need the file to stay in the same acrobat version.  We have an old program the replaces the the TitleBlock and BodyBlock text with some data.   The application that will not die!
      Anyone able to help me out?
      THANKS!!!
      PDF Template Template.pdf - Google Drive
      Logo - Landscape Structures black_2014.png - Google Drive https://drive.google.com/file/d/0B81kbk9FM_xac2lnMkVPYkhZOTg/view?usp=sharing
      Here is the data in the file with most of the image data removed to save space
      %PDF-1.2
      %âãÏÓ
      8 0 obj
      /Length 9 0 R
      stream
      q
      204 0 0 76.5 204 661.5 cm
      /im1 Do
      endstream
      endobj
      9 0 obj
      38
      endobj
      6 0 obj
      /Type /XObject
      /Subtype /Image
      /Name /im1
      /Filter [ /ASCII85Decode /DCTDecode  ]
      /Width 272
      /Height 102
      /BitsPerComponent 8
      /ColorSpace /DeviceRGB
      /Length 7 0 R
      stream
      s4IA>!"M;*Ddm8XA:OX[!!*&R!(-_m"pP8:"pbJ?#n71J$4RRW%1N^Y)As5#'Gq]0
      REMOVED RAW IMAGE DATA FOR SPACE SAVINGS
      8L0Hj,a)O7d.\:C/)4#o,a(_EP$e7:pD**Hgep]hP"?p^?iSRK(%*U-;Fr-s8L0I+
      s3p]WmOR'j8L0Hj,a)O7eFs^G/)4#o,a(_EP$e7>pD**Hgep]is4I~>
      endstream
      endobj
      7 0 obj
      34025
      endobj
      12 0 obj
      /Length 13 0 R
      stream
      Q
      BT
      255 629.25  TD
      0 0 0 rg
      /F0 24  Tf
      -0.0672  Tc 0  Tw (TitleBlock) Tj
      -183 -30  TD /F0 14.25  Tf
      0  Tc 0.1875  Tw ( ) Tj
      3.75 0  TD /F0 9.75  Tf
      0.0643  Tc 0  Tw (BodyBlock) Tj
      ET
      endstream
      endobj
      13 0 obj
      186
      endobj
      4 0 obj
      /Type /Page
      /Parent 5 0 R
      /Resources <<
      /Font <<
      /F0 10 0 R
      /XObject <<
      /im1 6 0 R
      /ProcSet 2 0 R
      /Contents [ 8 0 R 12 0 R  ]
      endobj
      10 0 obj
      /Type /Font
      /Subtype /TrueType
      /Name /F0
      /BaseFont /TimesNewRoman
      /FirstChar 32
      /LastChar 255
      /Widths [ 250 333 408 500 500 833 778 180 333 333 500 564 250 333 250 278
      500 500 500 500 500 500 500 500 500 500 278 278 564 564 564 444
      921 722 667 667 722 611 556 722 722 333 389 722 611 889 722 722
      556 722 667 556 611 722 722 944 722 722 611 333 278 333 469 500
      333 444 500 444 500 444 333 500 500 278 278 500 278 778 500 500
      500 500 333 389 278 500 500 722 500 500 444 480 200 480 541 778
      500 778 333 500 444 1000 500 500 333 1000 556 333 889 778 611 778
      778 333 333 444 444 350 500 1000 333 980 389 333 722 778 444 722
      250 333 500 500 500 500 200 500 333 760 276 500 564 333 760 500
      400 549 300 300 333 576 453 250 333 300 310 500 750 750 750 444
      722 722 722 722 722 722 889 667 611 611 611 611 333 333 333 333
      722 722 722 722 722 722 722 564 722 722 722 722 722 722 556 500
      444 444 444 444 444 444 667 444 444 444 444 444 278 278 278 278
      500 500 500 500 500 500 500 549 500 500 500 500 500 500 500 500
      /Encoding /WinAnsiEncoding
      /FontDescriptor 11 0 R
      endobj
      11 0 obj
      /Type /FontDescriptor
      /FontName /TimesNewRoman
      /Flags 34
      /FontBBox [ -250 -216 1163 1000 ]
      /MissingWidth 323
      /StemV 73
      /StemH 73
      /ItalicAngle 0
      /CapHeight 891
      /XHeight 446
      /Ascent 891
      /Descent -216
      /Leading 149
      /MaxWidth 969
      /AvgWidth 401
      endobj
      2 0 obj
      [ /PDF /Text /ImageC  ]
      endobj
      5 0 obj
      /Kids [4 0 R ]
      /Count 1
      /Type /Pages
      /MediaBox [ 0 0 612 792 ]
      endobj
      1 0 obj
      /Creator <FEFF004D006900630072006F0073006F0066007400200057006F00720064>
      /CreationDate (D:19990813124529)
      /Title <FEFF00540065006D0070006C006100740065002E005000440046>
      /Author <FEFF0062006D0061007200740069006E>
      /Producer (Acrobat PDFWriter 4.0 for Windows NT)
      endobj
      3 0 obj
      /Pages 5 0 R
      /Type /Catalog
      endobj
      xref
      0 14
      0000000000 65535 f
      0000036269 00000 n
      0000036146 00000 n
      0000036549 00000 n
      0000034636 00000 n
      0000036185 00000 n
      0000000128 00000 n
      0000034354 00000 n
      0000000019 00000 n
      0000000110 00000 n
      0000034794 00000 n
      0000035885 00000 n
      0000034375 00000 n
      0000034616 00000 n
      trailer
      /Size 14
      /Root 3 0 R
      /Info 1 0 R
      /ID [<1973bad288d6c29740e79a67b76532b0><1973bad288d6c29740e79a67b76532b0>]
      startxref
      36598
      %%EOF
        • 1. Re: Modify an old PDF from 1999 - PDF Version 1.2(Acrobat 3.x)
          Karl Heinz Kremer Adobe Community Professional
          A correctly written application that can read and process PDF should not have a problem with PDF files with a higher version number as long as the actual language features used were supported in PDF-1.2.
          If your application is trying to replace information in the file without a full PDF parser, then you need to find an old version of Acrobat, and the operating system that goes with it. No modern version of Acrobat will very likely create a file in the format that your application assumes the file to be in.
          There is one other option, and that is to "surgically" replace the image in the file with the new one, but that would require a very good understanding of the PDF specification. If you are interested in my professional help with this, feel free to get in touch with me via  email  - my contact information is on my profile page.
          Maybe it's time to replace this application that won't die with something more modern
          • 2. Re: Modify an old PDF from 1999 - PDF Version 1.2(Acrobat 3.x)
            Hmm, this "editor" replacing TITLEBLOCK etc will also damage the PDF. Acrobat may repair it, depending on the version, other apps may fail.
            • 3. Re: Modify an old PDF from 1999 - PDF Version 1.2(Acrobat 3.x)
              Ha!  Replace the app...
              So many projects and this one just chugs along, since it keeps working other than the logo it has yet to make it to the top of the list.   Just trying to make marketing happy for now.  Will contact you.
