1 Reply Latest reply on Aug 1, 2008 7:47 AM by larksys
    cfgrid valuesdisplay
    larksys
      The following grid provides the correct drop down list but when displaying the value of the column it show the actual value and not the display value that I want. It should be showing initials and not the ID for those initials stored in the database.
      You can go to tax.avericom.com/control and log in as temp/AdobeLabs. On the drop down menu select client services then client searches. Type 2478 as the search number in the top box then select it from the list. When the next page loads, click on the candidates tab. The recruiter_referral column should show the drop down. If the entry is blank the drop down works properly. If it is not blank, only the selected item show. The value in that column shows the stored value from the database and not the corresponding value from the list.
