3 Replies Latest reply on Oct 29, 2017 12:19 AM by Gutterfish
    How can I create an intro like this on After Effects?
    TheRobOng
      Hi, I am new to video and I am trying to learn how this guy does his intro for his YouTube videos (link provided below). I've tried searching it up on my own, but so far I am only able to get the fade part and creating the text down, not quite sure how he creates and animates the boxes like that, and makes the subtle brightness near the end. If anyone can provide me with a step by step or can link me to a video tutorial that would be amazing.
      Thanks in advance!
      Video link - Feiyu A2000 Dual Handle Kit Review - Is this $800 Camera Gimbal worth it? - YouTube  (0:43-0:50)
        • 1. Re: How can I create an intro like this on After Effects?
          If this is what you are looking for:
          Start by breading it down. The square on the left can be created with one shape layer, stroke only and a trim paths animator added.
          The Text on the left is a separate text layer. The square on the right with the text is easily created by putting a text layer above a solid or a shape layer and then using the text as a track matte. The line of text at the bottom is another text layer.
          Parenting can be used to lock the left square and left text together and the right square and text track matte together. Then it is just a matter of setting in and out points, animating position and opacity. Really basic stuff.
          Because you could not figure this out on your own I strongly suggest that you start here: Basic AE
          Go through the first section completely, then dig into the middle and right sections to learn more.
          By the way, the animated title would be a single composition. You would never edit all those shots together in After Effects. That is what Premiere Pro is for. AE should only be used to create composites, effects, and animations that you cannot create in your NLE. More than 90% of my comps are a single shot under seven seconds because most of the films I work on don't have very many longer shots in any of the scenes.
          • 2. Re: How can I create an intro like this on After Effects?
            TheRobOng Level 1
            Thanks a bunch Rick, got most of it down!
            One final question, near the beginning of his intro, the right box seems to slowly fade into the video before sliding to its spot, how did he manage to get that fade in effect?
            • 3. Re: How can I create an intro like this on After Effects?
              Gutterfish Adobe Community Professional
              Keyframe opacity & position  Animation basics in Adobe After Effects
              Make an effort.
